Question about Kenwood Car Audio & Video
Kenwood car stereo older type works but no sound has v-off when you push buttonsdont have book cannot change to v-on ?
    Top Expert:
  • Kenwood Master
  • 10,535 Answers
Hi John Anderson, indicate the model of the Kenwood stereo that you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola John anderson, indica modelo del est?reo Kenwood que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Posted on Oct 09, 2019
6ya staff
SOURCE:
Anonymous
  • 8 Answers
SOURCE: i have bought a kenwood
Hi i have just looked up your stereo and that kenwood doesnt support mp3 playback.
Unlucky mate.
In order to play a cd like that the head unit must support mp3 playback
Posted on May 30, 2008
Anonymous
  • 25 Answers
SOURCE: kenwood car stereo
are you aware that when you short circut any audio output of any audio it can lead do destruction of th e concerned audio driver( ic or output transistors) try and check the output ic and the concerned area.
Posted on Sep 20, 2008
Anonymous
SOURCE: audacity input levels change with every new song
From what I hear, you should try a new sterio system. Plus, you could se if the wires are all plugged in maybe that could be the problem. If you need any more help, Message me at montanaandboostshow@yahoo.com. Hope this Helped!
Posted on Apr 21, 2009
kenw392
kenw392
  • 2226 Answers
SOURCE: I have a Kenwood car stereo KDC - MP4033 and the
check your speakers and speaker wires for shorts, and then disconnect power to the radio for a few seconds and reconnect it.
Posted on Nov 24, 2009
Don Reiman
  • 773 Answers
SOURCE: I have a Kenwood KDC 135 car stereo wont un mute.
behind the face plate there is a little recessed reset button. push it using the tip of a pen or similar. that will fully reset the radio to like it was when you bought it.
Some times head units hicup. this is how you reset it. In most error cases this solves the problem.
Posted on Dec 15, 2009
Cannot get it to power on How does it work?
Kenwood Excelon DDX9902S DVD receiver at Crutchfield ...
www.crutchfield.com > ... > In-dash Video Receivers Crutchfield Corporation
Rating: 4 - ‎21 reviews - ‎$674.99 - ‎In stock
Kenwood Excelon DDX9902S Android Auto integrates your phone's app with the ....deliver an ultra-clean signal for adding additional amps for even more power. ...... Only thing I can't get to work with the Apple Car Play is the ITunes radio.
Car Stereos FAQ - Crutchfield
www.crutchfield.com > ... > Car Stereos
Crutchfield CorporationJump to What's the best way to connect the Crutchfield wiring ... - A: Most CDreceivers will play at least ... for example, some receivers work with ... If you can'tfind a new cassette deck ... the remote wire did not power the amp .... KenwoodExcelon KDC-X399 ... 12 tips for getting the best sound quality in your car.
Kenwood KDC-BT362U CD receiver at Crutchfield.com
www.crutchfield.com > ... > All Car Stereos
Rating: 4.5 - ‎174 reviews
A smartphone haven With Kenwood's KDC-BT362U CD receiver, you can ... A newcar stereo offers power that's superior to most factory radios, along with .... Gettingthe installation kit and the wiring harness with my stereo purchase was great. .... Cons: Pandora did not work and I tried contacting customer service and their ...
Kenwood - Car-Audio FAQ
Jan 06, 2016 | Kenwood Car Audio & Video
Tip
Nokia E65 and Kenwood KDC BT100 bluetooth handsfree unit
you cannot use the Nokia E65 with KDC BT100 bluetooth handsfree unit (an external unit to add bluetooth capabilities to your compatible Kenwood car stereo) unless you are running a firmware release >2.x
You can read your Nokia phone's firmware release by typing: *#0000#
With any firmware older than 2.x, the phone will find the BT100 and even pair with it, but the phone will not show up on BT100's phone list.
In some cases, Nokia E65 can also *crash* the BT100 unit. If this happens, the BT100 will disappear from your car stereo's menu. The only way to bring it back to live is to unplug the power of your car stereo. A simple off/on cycle will not be enough.
on Dec 21, 2007 | Nokia e65 Cellular Phone
Get a sub-woofer to work
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 28, 2014 | Kenwood DPX500BT Bluetooth Indash Car...
Kenwood kax-38 amp. distorted sound from turnatable if connected to the phono rca plugs, but ok if connected to the CD rca plugs.
The phono sockets for this are at different line levels for that reason. Phone is for the turntable depending on the type. If it is a later model stereo and an older model cheaper turntable, it uses an older type of needle cartridge called ceramic. The signal output of it is higher than the later magnetic cartridges and may need a preamp (radio shack) to match the line level signal, allowing it to clear the distortion. If this scenario were reversed, using an older cheaper stereo with a later, better quality turntable, the opposite would happen. (signal to low) This preamp would amplify the input. I think you need what is called a matcher to lower the input signal instead of the preamp. I've seen these at radioshack. BTW, the CD input doesn't distort as much because a cd player puts out a high signal and the amp is matched to accept it.
Dec 03, 2013 | SR-10 Adpater Cable - Kenwood Twin-Pin...
I bought an rcrn04gr universal remote to run my kenwood home stereo but can't find the right code
Make a code search process. If there is any code programmed with your device, with remote control, you can access it.Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Check associated ads too. Sometimes, it might help you.
May 03, 2012 | RCA Televison & Video
Dec 15, 2009 | Kenwood KDC-135 CD Player
Will the Kenwood KDC 1032 RCA outputs work with an ipod adapter similar to an aux output? If so, how?
Hi, if you are trying to get your I-pod to play through your car stereo, then you would need to have the RCA inputs, not outputs. If you connect your i-pod to the stereo outputs it won't work because both things are trying to push sound out of their outputs. If you connect the adapter to the stereo's inputs then it would work.
Aug 11, 2009 | Kenwood KDC-1032 CD Player
I have bought a kenwood kdc-241 car stereo i have downloaded my mp3 s onto cd-r (about 60 of them)when i put it into car stereo they play but no sound comes from the system (the radio sound is working also...
Unlucky mate.
May 30, 2008 | Kenwood Car Audio & Video
My car stereo cd player no sound
what are you trying to plug into USB? if an iped it required Kenwood IP200 Adapter
May 03, 2008 | Kenwood KDC-135 CD Player
Forgot my code.
What button should I push if I don't have an "auto" button, both on the remote or the head unit? I have a dNx-5140. All help would be appreciated.
Aug 27, 2007 | Kenwood KDC-MP4028 CD Player
Open Questions:
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
