Humidifiers Logo
Zizi Cin Posted on Oct 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does E9 mean when you see it show up on your Hisense humidifier 70 gal.
Archana Baldwa
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 06, 2020
Archana Baldwa
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
214
Points
12
ChinthakaJ
Level 3:
  • Master 943 Answers
  • Posted on Jan 09, 2020
ChinthakaJ
Master
Level 3:
Answers
943
Questions
Helped
301505
Points
2783
Could be 2 reasons.
1. It's the humidity sensor.
2. blocked drain line.
Mainstays Cool Mist Humidifier 1 gal MDH-0103JW Low Tank Indicator Auto Off NEW Manual
Here are the instructions for the Mainstays Cool Mist Humidifier 1 gal MDH-0103JW:
  1. Remove the water tank by lifting it straight up and off the base.
  2. Turn the water tank over and remove the tank cap by turning it counterclockwise.
  3. Fill the tank with cool water and replace the cap by turning it clockwise.
  4. Place the tank back onto the base, making sure it is seated securely.
  5. Plug the humidifier into an electrical outlet.
  6. Press the power button to turn on the humidifier. The power light will illuminate.
  7. Press the mist button to select the desired mist output level.
  8. The humidifier will automatically shut off when the water level in the tank is low.
  9. To refill the tank, repeat steps 1-4.
Note: For optimal performance, it is recommended to clean the humidifier weekly. Please refer to the user manual for detailed cleaning instructions.
Nov 06, 2022 • Humidifiers
My Hisense 70 pt. Humidifier keeps shutting down and reads E9
It's the humidity sensor error or the drain line is blocked.
Oct 09, 2019 • Humidifiers
How much water gal/hr is reasonable to expect from the furnace humidifier overflow in "0 degree" farenheit outside to heat a 1500 square foot normal midwestern house to 72 degrees inside having a norm
There is no flow rating because it would depend on too many factors. What you do need to check is the float valve. The water valve is opening and closing like it should be but the reservoir is filling too much.
Jan 23, 2015 • Humidifiers
HM512W1005 HONEYWELL TRUESTEAM light flashes 6 times. What does that mean? Also, where can I get a list of codes? Thanks
I recently contacted Hunter and they said the loud motor in the Hunter 34357 humidifier can NOT be replaced. Instead, they can provid a pro-rated refund, depending on how long you have owned your humidifier. A receipt from your purchase is needed to get a refund. Contact Hunter at http://www.hunterfan.com/Support/Contact-Us/
1helpful
I need the operation manual for the Honeywell quick steam humidifier HWM335, 3 gal. please
Here is a link to your Owners Manual that you can download and print. Please do not lose it, as this model has been discontinued by Honeywell.
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/QuickSteam-OwnersManual.pdf
How many square feet is the humcclbp2317-a-- good for?
Yours is 17 gal a day. Could only find Honeywell which recommends their 12 gal up to 2000 Sqaure foot home. So yours should by good around 2500 to 3000 square feet
HOW TO REPLACE FILTER #wf813
It's easy to find a replacement if you know what the model number is of the humidifier. If you do, let me know.
2helpful
Honeywell Natural Warm Moisture Humidifier Is On But No Steam?
I have the same problem and I have 2 of them fairly new. I can't seem to find out what the problem is either.
Stumped?????????
Aprilaire 600 bypass water flow rate
The water is only dispensing over the evaporator pad while the furnace is in the heating mode. When the furnace finishes cycling the humidifier will also stop.
Top Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Humidifier Expert? Answer questions, earn points and help others
