I dropped my tablet on vinyl/wood floor. fine for 1 1/2 days. It's frozen on sign in pg. Touch screen won't work. Will charge.
SOURCE: Touch Screen not working or Pen?
in my opinon. you should be re instal this touch pad driver.
SOURCE: i have a Toshiba tablet M780-s7230 and i tried
Have you turned on the Touch feature on Windows 7 yet? That could be the reason why your touch screen feature is not working.
To turn it on please follow this:
1. Open your Start menu and type "Touch" into the search bar. This will show a variety of options, including the "Pen and Touch" options. Double-click it to open the "Pen and Touch" window.
2. Check the boxes next to the "Use your finger as an input device" and, if preferred, check the "Enable multi-touch gestures and inking" box as well.
3. Click "Apply" to set the options and click "OK" to exit the window.
Hope this helps!
SOURCE: tablet is frozen will not
Try one of the following:
- Hold the power button for 10 seconds
- Hold the power and up volume for 10 seconds for recovery mode
- Hold the powe and down volume for download mode for 10 seconds
If none of these work then your battery might be completely drained and dead. I suggest you send your contact Samsung Support.
Hope this helps.
SOURCE: yes I dropped my galaxy
Send it back to the manufacturer for repair or get a new one. You cannot repair this yourself.
SOURCE: I accidently dropped my tablet and cracked the
Here is a best buy in your area. The geek squad will be able to send your tablet out to be fixed.
http://stores.bestbuy.com/133/
