Welding Tools Logo
G
Garry Yarboro Posted on Oct 09, 2019
Ow to put wire in welder - Welding Tools
Cory Davis
Level 1:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 17 Answers
  • Posted on Oct 19, 2019
Cory Davis
Contributor
Level 1:
Night Owl:
Welcome Back:
Answers
17
Questions
0
Helped
2589
Points
32
Depending on what type of it is a self feeding there is a door on the side that should open up and a place where you put your spool of wire then you just feed the wire through the allotted spit and slowly squeeze the trigger to have it feed through you lead.
Why does my welder keep feeding wire?
Question moved from Vacuum Cleaners to MIG Welder category.
Tell Brad Brown what the model is because he is our Welding Expert. I just know a bit, but can find stuff :>D
Continuous wire feeding is a common issue. Check out the videos.
https://www.google.com/search?q=welder+keep+feeding+wire
Unit starts and puts out electric, but will not weld in any position, where do I start to check
If your Miller Trailblazer 302 AC/DC welder generator is starting and putting out electricity, but will not weld in any position, there are a few things you can check to troubleshoot the issue:
  • Firstly, check the welding cable connections and make sure they are secure and clean. Check the cable itself and make sure there is no damage or corrosion.
  • Secondly, check the welder's ground clamp. Make sure it's clean and tight, and that the ground connection is secure.
  • Thirdly, check the welding gun liner, and make sure it's not blocked or damaged, this can cause the wire to feed improperly.
  • Fourthly, check the wire feeder, make sure it's functioning properly, and that the wire is feeding smoothly.
  • Lastly, check the voltage and amperage of the welder. Make sure it's set to the correct settings for the type of welding you are trying to do.
It's important to check the manual of the welder for troubleshooting steps and also check the warranty of the welder and see if it's still covered by the manufacturer. If you are not able to find the problem or if you are not familiar with welding equipment, it's best to take your welder to a qualified Miller Electric welder repair service center, they will be able to diagnose and fix the issue.
Wiring a welder 480v to 220
I ahve a linclon ideal arc 250 welder which is 480V 3 phase I would like to change it over to 220V single, what are the procedures.
1helpful
Wire feed stopped after tack welding on set-up jig
i had the same problem. its probably a bad solder on the wire feed pot. not hard to fix ,but you need a solering iron .BE CAREFULL 1 unplug welder.
2 remove pot and the nut underneath.
3 remove case from welder and remove controll box.
4 run the soldering iron over the joins , then put it all back together, should work fine.
My welder just stopped welding. It's a Telwin 220 Mig. The fan is still running but there is no noise from the welder and the wire is not feeding. I had only used it for around 30 seconds before it...
your feeder may need adjusting or more commonly the tip has tacked itself on the edn cap
keep the line as straight as you can & keep feeder compartment clean!
keep plyers handy for when wire is stuck in the tip
if you need to replace wire spool or a brakage of the wire make sure the wire is free or BURRS b4 you put it in the tube or you will damage the tube!
Cheer Rob.
1helpful
My welder wont work
this is a very cheap welder ,so dont hope for a lot out of this welder.any who this is called a feeder hose.and you'll have to practice running the wire th ru this feeder hose to straighten the wire out till the wire goes th ru the hose do not have the wire going th ru the machine that the clamp is tightened tighten after the wire is through.and then the wire should only be tight enough to push the wire through ,thats something you ll have to play with to get it right.hope this helps .jojogunne
Excessive wire speed on hobart ironman 250
to find out if you need a new reostat disconnect the wires from it and put an ohm meter on it and check the ohms resistance it should read up and down ohms as you turn the dial.
Top Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a Welding Tool Expert? Answer questions, earn points and help others
