It has EMUI in a circle on the screen and underneath that, there are 4 options for me to select.
SOURCE: IBM T22 Thinkpad won't boot up - not even in safe mode
either you have a virus or a corrupted dll file.
eitherway, beside create a bootable CD or Floppy disk, and try to fix from there, thats' time a money.
the next best thing, is to reinsall the operating system.
the other option is get a new hard drive and install the operating system on that so you can preserve the data you have on the old one.
SOURCE: How to remove BIOS memory cache
Since it is a Toshiba Tecra if you are not worried about losing data on the laptop you can try turning on the laptop and start pressing the zero key. It should give you the option to restore your laptop if you haven't deleted the restore partition on the laptop.
SOURCE: Computer keeps returning to "safe mode" options screen
If you choose Start Normal and it boots into safe mode again then you should get professional help if you value any of the files on your computer and don't want to loose any data.
SOURCE: vista boots just Black screen with cursor even in safe mode
Yes, this is a known issue with Vista. You need to back-up your data, format your hard drive and re-install Vista from the beginning.
There is really no use trying to repair it: it is damaged.
After you re-install Vista, do not forget to install service packs from microsoft.com.
Testimonial: "Thanks! Maybe I should consider the fact that I am using my perfectly performing Iphone to fix my poorly performing PC during my next purchase :-) "
