Hi Chuck Keplinger, so you say, you may have some LEDs in the backlight or the source that feeds them
If they are the LEDs, replace them completely, to prevent the failure from repeating in a short time
Hola Chuck Keplinger, por lo que comentas, puedes tener mal algunos LEDs de la iluminacion trasera o la fuente que los alimenta
Si son los LEDs, reemplazarlos por completo, para evitar que la falla se repita en poco tiempo
SOURCE: Sound but no picture on Vizio WS42L TV
did you ever get it resolve? I am having the same problem. my tv is a year and and 1 week old. I am so upset.
SOURCE: no picture on vizio 42
There are several boards that can cause what you describe. Can you bring up the menu? If so that will help in the process of elimination. Is there sound? What is the model number? Have you unplugged the set for a few minutes? If you are trying to decide whether to repair or replace. If any of the boards need replacing 250.00 to 500.00 for a shop repair.
SOURCE: Vizio P50HDTV10A TV went pop now has a black picture
Don't know which boards Z or Y have dead capacitors pop open,take ur tv aparts check boards that have pop opens parts or burn marks on them.Replaced that board will solved ur problems.Tries Shopjimmy.com,Ebay.com to buy refurbish boards for the replacement.
SOURCE: Vizio 42" tv has no picture but sound. What is
the problem is in your 42 tv bec.of your dirt tv ok
SOURCE: vizio 32" HD flat scene tv no picture no sound will not turn off
if no picture no sound how can it turn off--you mean a light is still on? Let me also know age of set and if any odd things before it failed like had to turn on several times etc.
