HD broadcast picture is not full screen. How do I enlarge it without distorting it? Using Comcast's Motorola HD tuner, a Sony Bravia TV, connected with coax and 5-connector component cable. I can change the picture to "FULL SCREEN but that only fills side to side. There are still black bars at top and bottom. FULL SCREEN and WIDE ZOOM distort the image (people look squished or fat).
Is there some setting I am not finding that will allow the picture to fill the screen on top, bottom and sides without distortion?
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
The tv Tuner signal board is dying and the causes.That the board,where all the output devices and the incomming broadcasting signal cable plug in.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
You do not want to buy HD ready (ready means it will accept HD sources), Ful HD TV will have ATSC digital tuner for off the air signal, you will want it to have QAM tuner also so if you decide to get cable, you can get unencryped HD programs without using the cable box (that is what I am using with my Entended BASIC Comcast cable without using/renting their box, Comcast gives three free boxes, then you have to rent the rest if you have more than 3 TVs at about $7 a month).
That sounds very normal to me. When your watching a HD channel, and a commercial comes on and the screen gets smaller with as you say the black bars, just means that the commercial is not broadcasting in HD. You can change it by pushing the button on your TV remote that says picture, but you are streaching the screen and are going to loose the quality of the picture. You may also want to spend a few hours, going into you TV settings and just start playing with the settings. Just remember where they were before you change something. You can also purchase a guide to LCD settings to point you in the right direction. If you have your TV set to vivid or one of the preset picure modes, it is costing you more power and you are not getting the best picture that the TV can produce. Play around with the custom setting or buy one of those calibration CD's off the internet.
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
assuming you all have comcast and using an hdmi cable first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
