Question about The Audio Players & Recorders
My mosta072 the cd door will not open. Can you advise?
    Top Expert:
  • The Master
  • 10,535 Answers
Hi L Wiggerham, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola L Wiggerham, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Posted on Oct 14, 2019
  • The Master
  • 5,699 Answers
Most CD drawers are activated by a belt system that can come off or break. If you can hear a whizzing sound coming from the unit when the door eject is pressed, then it's likely this has happened. Other possibilities are faulty switches or something jammed in the mechanism. Removing the top (with the power off) might reveal the problem.
Posted on Oct 12, 2019
6ya staff
SOURCE:
Hi I have a Sedona 2006 slideing door will close but not open unless part done manuly
it need more power to open the door incited of closing so i advise to visit the link for help
Aug 13, 2017 | Cars & Trucks
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
Hi, please can you advise on the HITACHI AXM898U micro hi fi where on the machine the CD is loaded in. There is a circle on the top of the machine which looks like it may be there, and there is also what...
This Player is a front disk loader. So it should be OK for you even if you are placing it on top of a shelf..The CD is loaded on a tray which is a thin rectangle door below all the buttons in front.
Mar 07, 2011 | Audio Players & Recorders
I have a cd that I would like to put on to my computer please can you advise me how to do it.It is a cd rom 700mb
On the right hand side of your laptop tehre shoudl be a thin compartment with a little square button. On teh right side of teh button tehre shoudl eb alable stating "lightscribe".
(This video shows the location of your CD-ROM, skip to mintue=1 seconds= 40 to 50).
With you PC "on", if you press the square button near the "lightscribe" logo, the CD-ROM compartment will pop open.
Open the door completly.
Here you can inster your CD.
Make sure you put the CD with it's lable facing "up".
Close the CD-ROM door complelty and the PC should start reading the CD.
Cheers,
Ed
Nov 24, 2009 | Compaq Presario C700T Notebook
CD/ROM Door automatically pops open, and then repeats after it is closed. Sometimes seem to be triggered by opening a random program.
sir
it is due to a virus called odiya or odissey in ur computer..i will advise you to install a good antivirus on ur computer and perform a full system scan
thankyou for using fixya
hv a nice day
dont forget to rate the solution
Mar 25, 2009 | LG GWA-4082N DVD RW Dual Layer Burner
Door
Hi abdu
The problem is that at some stage you or someone else forced the cd open or closed, but not to worry, it's not broken. What happened is that the gear that pulls the tray in, mite have slipped a tooth or two. You'll have to open it up. Take the top cover off. It has four small screws holding it. When you take the cover off, the gear system should reveal itself. Now the gear that pulls the cd tray in and out must me ajusted. Before you open the dvd writer, make sure it is in it's utmost closed position. Very Important!. There should be a screw in the centre of this gear. Carefully unscrew completely. Now it depends on which direction the gear turns when it close the tray. Seeing that it doesn close completely, the gear turns anti clockwise to close. Lift the gear in a up sliding position and turn it one teeth clockwise, press the gear back, fasten the screw and test. If it still needs more adjustment, repeat the process with another teeth clockwise. Note if it worsen that it doesn't close, then you need to reverse the process and move the gear anticlockwise, but make sure to mark the teeth that it was originally on when you opened it.
Hope this helps
Cheers
Deon
Sep 10, 2008 | LG (GCE-8527B) CD-RW Burner
CD ROM
If the drive door sticks after you have used the paper clip to open it, look under the tray at the drive teeth (if any). Apply a liberalm coating of general purpose grease to the rwo inches of teeth at the end of the drive tray nearest you and close the drive door again. Open and close a few times to see if the door is now free. This worked for me on my Dell Inspiron 3100. Try it.
Jun 24, 2008 | Dell Computers & Internet
HARMAN KARDON CDR-26 CD RECORDER/PLAYER
You need to clean the laser lense, if that doesn't work you need a new laser pickup. Check first, but from memory you need a sanyo sfp151 17 pin laser. Costs around $25.
Mar 08, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
26 people viewed this question
Top The Audio Players & Recorders Experts
Don Walper
Level 1 Expert
stephen Kiarie
stephen Kiarie
Level 1 Expert
Roy Cunningham
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
