How to change the baud rate?
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
SOURCE: How do I change baud rate to 9600 on Epson CX9400Fax?
This fax speed is 33.6 or 33600
You can change settings to 14.4 or 14400 but not to 9.6 or 9600.
Under: Fax Settings you have this choices:
Speed Dial Setup
Scan and print setup
Communication
Header and time
Under Communication:
DRD
ECM - error correction put this one: off
V.34 - this one is for speed: on - 34400; off - 14400
