JVC GR-D33US Mini DV Digital Camcorder Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot record due to a black screen
Black screen
screen cover is off
menu icons are warking normally
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Sep 17, 2009
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957016
Points
33084
OK, that means you can see clear picture in playback of old recorded tapes and camcorder just wont give you live view to record any more.
If its true then it is known problem/ failure of ccd imager in your JVC GR-D33 camcorder.
JVC will repair it free of cost, click JVC CCD Imager Advisory for details.
Thanks.
3 Related Answers
Anonymous
  • 326 Answers
  • Posted on Mar 24, 2007
SOURCE: No Picture in LCD or Viewfinder
Hello, please contact the Authorized Sony Service for Sony recall action. If you need more info please advice.
Anonymous
  • Posted on Apr 15, 2008
SOURCE: No Picture on the LCD screen or view finder
I Have Problem with DCR-HC30E Mini DV- There is no picure in LCD screen as i can see all my menu items and pre-recorded videos. when I try and record the screen is pitch black even though audio is recording.
Is anybody can help me to solve this problem
Anonymous
  • 10594 Answers
  • Posted on Jan 12, 2009
SOURCE: There is no picure in my view finder or LCD screen.
Its known issue of bad CCD imager in DCR-HC30 and CCD imager will be replaced.
Sony will repair your handycam free of cost as per announced scheme of CCD problems.
Click on Sony CCD Support for details.
My galaxy tab 3 never goes to sleep to a black screen. The wallpaper is always there. Is this normal
at the home screen, touch the app menu icon
choose settings
choose timeout
choose timeout value from the list (one minute timeout standard value)
touch the home icon button to return to the home screen
tip
Black and white or negative screen resolution in Mac OS X
A black and white display, or negative screen resolution, is an issue which can occur within the various Mac OS X system versions ranging from Mac OS X 10.3 to Mac OS X 10.6.
It can appear as an anomaly which can leave a Mac User dumbfounded, not sure what is going on.
At one time your screen is normal like this, but then somehow,
the screen changes into this strange negative, inverted screen.
So how does this occur?
The answer is more simple than you think.
An inverted screen like the one you see in the screen shot above, is not actually an anomaly, or the result of some sudden strange happenstance. What's more, chances are, this occurred because of what you did.
Its an easy fix however, because the only way your Mac OS X desktop screen can turn into a negative or black and white resolution, from its normal color resolution, is if a setting within your Mac OS X system has been modified.
To return your screen back to the normal color resolution, follow these steps:
* Click on the Apple menu icon, located on the upper left corner of your Mac OS X desktop screen.
* From the drop down menu, select System Preferences.
* Within System Preferences, select the pane (in System Preferences, Apple references all icons as "panes") entitled "Universal Access".
Quick Note About Universal Access:
The reason this System Preferences pane is known as"Universal Access", is due to the purposes Apple designed it for. If you notice the image for this pane above, this symbol for this feature, is similar to a placard or sign you would see on a car license plate, parking space, door or building, for an individual who has a disability or is handicapped.
Universal Access was designed to enhance features like Voice-over speech (your Mac talks to you), screen size, display settings, keyboard and mouse settings for those Mac users who are vision impaired, hearing impaired and /or physically disabled.
* For the next steps in the process:
Click on the Universal Access pane.
If you look in the screen shot, under Display, you will see that the current setting is "White on Black".
Click on the radio button entitled "Black on White"
and this is the window you will see:
Back to normal!
That is all it takes, to return your desktop screen resolution back to normal.
This is why you were suggested as the probable cause" for your desktop screen to go into Inverted mode. Chances are you may have been in System Preferences, clicked on the Universal Access pane, and in exploring settings, may have clicked the Display setting and the
White on Black radio button, causing the screen to go into
the inverted mode or change in gray scale.
Another theory could be that you may have accidentally pressed the Ctrl-Alt-Apple Command keys on your keyboard, combined with either < > keys, depending on if you were in process of' increasing or decreasing contrast on your Mac's screen or display.
The true purpose of the inverted screen mode or change in gray scale, is to aid Mac Users who may be sensitive to the bright normal colors, that you and I see on the standard Mac OS X display screen, due to poor or failing vision.
So now that your screen is back to normal, if you should see an inverted display, or screen that resembles a negative resolution, like that of a photo negative, you know how to correct this issue.
For more information on Universal Access, click here.
Regards,
- Mactechtrainer
on Feb 08, 2010 • Computers & Internet
How do I remove video icon
That means the camera is recording normally. Stop recording by pressing the record button. If that doesn't fix it for you, try resetting the camera to factory default options.
2helpful
All of the icons are still visible, but otherwise, the screen of my t99 is showing up blank. The camera still takes pictures, but the photos are black and so is the display. Please help! No temperature...
This may be due to the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD image sensor issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETTINGS-->MAIN SETTINGS-->INITIALIZE-->OK.
You may also try power resetting the camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
The monitor won't show the full screen about a 4inch black screen on the left side and I can't drag to fit
you need to scale your screen more through the on screen menu buttons on monitor. just expand the screen so that it coveres the black area, due to somne reasons the horizontal scaling has been fiddled..
3helpful
There is no picure in my view finder or LCD screen. I have all of my display menu's and such, but no picture, and yes the lense cover is down. There is a small eye looking icon in the screen, and I can...
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
3helpful
How do I turn my flash off on my samsung digimax 4010
You don't say which model Digimax you have. Hopefully this will cover most models.
First, make sure the menu is not being displayed on the LCD monitor, otherwise you'll just move around in the menu screen. You must also be in photo record mode, ready to take a picture (not in playback or movie mode).
There is a button (usually on the left side of the direction pad) that looks like a lightning bolt. I can't remember the exact number of times you must press it, but the display should indicate that the flash is turned off as one of the options as you cycle through them.
Depending on your model, the modes are likely to be Auto Flash (bolt with an "A" icon), Auto with Red-eye reduction ("eye" icon), fill flash - always on ("bolt" icon), Slow sync (bolt with an "S" icon), and flash off (bold with a line through it icon).
Also depending on your model, you may not be able to turn the flash off depending on which recording mode you're in. For instance, you can't turn the flash off if you're in the "Backlight" recording mode.
Dec 13, 2007 • Cameras
1helpful
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
