If you check out the link below you will see your engine basic type is listed but without the suffix though that isn't likely to be an issue as all the Tecumseh OHV engines listed all have the same 0.004" (4 thou) intake and exhaust valve clearance - it is unlikely your engine will be different...
https://www.allotment-garden.org/rotavator-manuals/Tecumseh4cycleoverheadvalveenginesmanual.pdf
Testimonial: "Thanks for info it is very much appreciated and I"
SOURCE: I have a Tecumseh 12.5 hp vertical ohv engine
My 13.5hp ov358ea is .004 both valves. Would like to know model of your engine. I want to replace the non-adjustable carburetor of my 13.5hp ov358ea with an adjustable carburetor.
Retired Airline Mechanic
SOURCE: Tecumseh 16 hp ohv adjustment
It is always best to have the exact model number of the engine you want to work on. Here is a helpful link:http://www.tecumsehpower.com/CustomerService/BSI.pdf
SOURCE: what is the valve clearance on a 13.5 hp Tecumseh ohv 130 motor?
Set the intake and exhaust both at .004. This should get you running smooth. GOOD LUCK FRIEND.
