Https://www.fossil.com/content/dam/fossil/PDF/watchinstructions/Fossil_Watch_Instructions_EN_UK.pdf
Usually pull the stem out and rotate.
SOURCE: Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
SOURCE: Question:how to set the weekday on a Fossil watch model BQ-9165.
You have to pull out the stem all the way and turn clockwise until you get to the correct day. Hopefully you won't have to wind thru the whole week.
SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
SOURCE: setting m/d/s
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all FOSSIL watch manuals. Rate me, please .
