Question about Samsung Washing Machines
My special sweater detergent suggests not to rinse. how do I skip rinse cycle on my front load Samsung WF455
  • Samsung Master
  • 6,083 Answers
I suggest you read the operating instructions of your machine. I don't know of such a programme - most programmes include a rinse and spin though there is usually a delicates programme that is a short low temperature wash, leaves the tub full of water (to decrease creasing) until the programmer is advanced and then a short rinse and low speed spin.
Not sure what is special about a special sweater detergent except maybe it is so mild it might behave like soap and contains a fabric conditioner - hence no rinsing. Seems it could be a gimmick...
Best way of washing treasured woollens remains hand washing using soap if possible and rinse with fabric conditioner. Pull into shape while wet and dry flat.
Posted on Oct 13, 2019
Testimonial: "Thanks for your advice. I did read the manual and in the end decided to use the wool cycle. The reason for the no rinse: Its a special detergent for cashmere with eucalyptus. Note the eucalyptus helps prevents moths! I have used it successfully for hand washing one sweater but I had four so decided to use my washer. I just blocked them and they are drying. Thank you."
  • Vernon Taylor Oct 14, 2019
    Matter of interest, cedar wood lined closets, drawers and wardrobes also deter moths and bugs and cedar oil is another natural deterrent.
Anonymous
SOURCE:
prem mathew
  • 1294 Answers
SOURCE: Frigidaire Front Load Washer Problem
Plug off the wall, open up the back to check your belt, might have come off. Place around motor pulley & turn the drum wheel to slip on the belt gently from either the right or left. If too loose you have to replace with new belt.
Rate if helped pl..................
Posted on Jan 04, 2008
bbtoast
Brian Berndt
  • 319 Answers
SOURCE: Detergent accidentally put into rinse dispenser
You need to use something to siphon the detergent out of the dispenser. I have plastic syringes for this type of purpose. You don't use the needle attachment.
If you cannot fit the syringe into the opening, then you may try to use clear plastic tubing to syphon out the detergent.
Once the flow of detergent stops, you should then use warm water to rinse the residue. If you have the syringe, you could use it to force water into the dispenser.
This may take a little time, but it is better than trying to disassemble stuff!
Good Luck
Brian
Posted on Jan 10, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Posted on Mar 22, 2008
vickyc
SOURCE: Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
Posted on Apr 22, 2008
Mr-Electro
Alain Vaillancourt
  • 120 Answers
SOURCE: WhirlPool Front Load Washer Leaking
to richhardh..
did u try holding the "End of Cycle Signal" button for 3 ?
Posted on May 24, 2008
LG front load washer leaves clothes soapy. Yes cleaned trap and drum and use correct HE detergent. What else can it be?
front load machines can be soo frustrating-try using less detergent-you might try running a sanitizing cycle with a quarter cup of dry dish washer soap-sounds like your rinse cycle isn't working do you have an option for a 2nd rinse cycle-cheers Denny
Oct 26, 2013 | Washing Machines
I have a lg wm2277 front load washer and the liquid soap cup gets clogged and when I open the tray after the load is finished, it will be full of water. I have tried cleaning the cup but the white stuff...
Switch to powdered detergent. You'll be much happier in the long run. Liquid detergent leaves a residue. Eventually the residue mildews. Powered detergent leaves no residue. Plus you will solve your current issue. Also skip the softener and use plain white vinegar in its place. The vinegar helps eliminate mildew and it also helps release Dey from your clothes in the rinse cycle.
Jan 06, 2018 | LG WM-2277HW Front Load Washer
I would like to know what laundry detergent and softner to use in my front load, and the right amount to use. I buy the H E products and some of them are really sudsy in the wash sink and I have this awful...
You should use HE detergent following the directions for that detergent. You can add liquid fabric softener. Make sure to fill the appropriate compartment to the Min line if you are doing a small load.
I've never used a washer that drained into a sink (always had a stand pipe). However, I suspect that the gummy residue is the excess softener that was removed in the rinse cycle. Try rinsing the sink with hot water after a laundry. This is part of the procedure to clean the inserts and detergent/bleach/fabric softener drawer when you get a build up in the drawer. In the future, use less fabric softener in the washer. Alternately, skip the fabric softener in the washer but use a dryer fabric softener.
The manuals for most Frigidaire appliances are available from http://www.frigidaire.com/manuals .
The direct link for the manual (in English) for the is: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134609000een.pdf .
I hope this helps.
Jun 05, 2011 | Frigidaire ATF6000ES Front Load Washer
Does kenmore recommend liquid or powdered detergent for front load machine
liquid is best as powder is mostly made of a "clay base" in its detergents??? yes i did say clay!
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
Water will not drain during the rinse cycle
A lot of those front load type washers have problems resulting from overuse of detergent. You should remove the panel and clean ot the sludge and lint inside. Service Manualb8c024f.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 07, 2010 | GE Energy Star WCVH6260F Front Load Washer
My washer stops during the wash cycle and "sud' come on. i can sht off and turn to rinse and spin and it completes that. what should i do/
thats easy,front load washers use little detergent,if this problem arises start the machine and use cold water,it will get rid of the suds,you are using to much detergent,the make a special detergent for front load,theres an air vent that needs to get air and if it suds to much it will not breath probably and the suds word will show up
Feb 06, 2010 | Whirlpool Washing Machines
My bosch does not always completely wring the clothes out at the end of the cycle causing me to have to put the clothes through another wash. Has anyone had this problem?
...at the end of the wash, I then set the dial to DRAIN, then press start.  I wait for a special drain cycle to run.  Then, I set the dial to SPIN, and wait for a special spin cycle to run.  The clothes are much dryer and spun out after this process.  I'm not happy with the washer, it came with my new condo.  BUT, I'm trying to learn how to use it.....
Aug 23, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Oder inside washer
On newer other machines, there is a cleanout cycle that uses 2/3 cup of bleach, no detergent and I believe uses more water. Suggest you use a load of white towels, no detergent, the bleach and put it through a normal or soak cycle where the bleach has a chance to kill off the germs and other bacteria, then rinses itself clean. They also recommend that the door be left open on these machines to allow the moisture to clear and dry assisting in curtailing further development of the same. The cleanout procedure they present is suggested for monthly using their special cycle which doesn't exist on my HE3T either. Hope this helps some. NOTE: There are cautions about leaving the high level of concentrations in the washer for extended periods or too often.
Sep 08, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Fabric softener not draining during rinse cycle
What type of water hoses are hooked up to it? If you have the flood safe hoses with the check valve in them then there isn't enough water pressure to distribute the softener.
Apr 25, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
301 people viewed this question
Top Samsung Washing Machines Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
