Question about Electrical Supplies
Kings craft generator what do when the circuit breaker overload shuts It off
    Master:
  • Electrical S... Master
  • 411 Answers
Diesel generator set: www.dieselgeneratortech.com
Posted on Oct 16, 2019
6ya staff
SOURCE:
Anonymous
  • 1605 Answers
SOURCE: I have 2 siemens circuit breakers that won't reset. How can I do
unplug the appliance that is overloading the breaker.
reset the breaker, plug in the appliance. if the breakers pops, then the appliance is the problem.
you may want to check the appliace manual and make sure the breaker is rated for the appliance you are using.
Posted on Dec 30, 2008
Anonymous
SOURCE: correct wiring for delta wired motor
check & confirm the following
1. delta connection of the motor is done properly, with the combination of different windings.
2. check the quality of the 3 pole mcb or check with other one.
you can call me in 00971508105450 or mail me a00971508105450@hotmail.com
Posted on Mar 13, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: Breaker trips when pump is turned on
make sure the amperage on the motor doesn't need more than the breaker you have. it should tell you on the name palte or the manual how many amps it uses under a workload. if it's worked before this, then maybe the motor is seizing or has a short.
Posted on Aug 12, 2009
christian nielsen
  • 358 Answers
SOURCE: Frig keeps overloading circuit breaker, just repaced relay
I think the compressor has a problem with its internal running coil , or it's grounded.To check it you can disconect the power to the compressor and then turn on the breaker , and if doesn't tripped the breaker ,you know the compressor is bad.
Posted on Sep 06, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: shuts house circuit breaker off shuts house circuit breaker off
Breakers can get worn out and trip when they didn't earlier.The wires to the breaker can work loose over time.
Posted on Apr 24, 2010
My kings craft generator not sewing machine
Try posting under the correct category.
Jan 05, 2017 | Sewing Machines
I have a kings craft and it want start it is the 1705 and I've had it for 3yrs andused it 1 time help me.
What would you like to know?
Fill oil to the top, add unleaded fuel, and pull the recoil to turn over engine 3 times. This should prime the carb. Then start!
If it is still not starting, please contact us. We are always happy to talk you through it.
https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
Jan 05, 2017 | Electrical Supplies
When I plug in a tool, it runs fine, when I plug it into my house with the breakers all off, it blows the breakers on the generator? My Honda 2200 watt works fine this way?
I think there is overload .kindly measure ur load of consumption. Do not run the generator set with high load it can be cause of circuit breaker Tripp off .
Oct 27, 2015 | Honda Electrical Supplies
Generator was running just fine. it's a bsv5500-w overloaded the unit by mistake. tested with meter and found 86 volts. shut unit down and now only puts out 5 volts on each leg
are you sure the breaker didnt trip when overloaded,as this is what the breaker is for and would explain the ghost voltage of only 5 volts at the outlet
May 30, 2011 | Porter Cable 5,500 Watt Portable Generator...
Does generator need to be grounded
ALL AC electric needs a ground for safety and somewhere for the excess power to go, you dont want to hook one into your house with out a ground it will just overload circuits and throw breakers with a possibility of damaging electrical appliances, all you really need for a good ground is a 2 foot rod driven into the ground about 14-16 inches, or you can just use the one already around your home
Jul 03, 2010 | McCulloch Electrical Supplies
I was running two sawzalls on my pmo43350 coleman generator .Now it stopped producing electricity. the engine runs great but no juice to outlets. ithink i overloaded it.
You may have overloaded it, and it may have been damaged.
Check your circuit breakers first. If there was an overload, they should have tripped if overload was long enough in duration and high enough in capacity.
If the breakers are good, then check your diodes and capacitor regulator in the end of the alternator. While you are here, check your brushes as well.
Do you have a manual for your generator?
Jun 25, 2010 | Coleman Powermate Premium Plus 6250W...
6500 watt diesil generator /as soon as i put any
if by fliping the breaker it shuts off..that means there is a short circuiting in the breaker..try connecting your house,shop..etc..directly ...
that is if the shut off reason is overloading...if not please explaing with details
Aug 23, 2009 | Electrical Supplies
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
Electrical Supplies Logo
50 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
