Question about Procom Heating & Cooling
Need to convert my Procom FBD400T fireplace for remote operation
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 25 Answers
Here is a link to what you will need.
https://www.techxdirect.com/remote-controls/
Posted on Oct 15, 2019
3 Suggested Answers
Anonymous
  • 188 Answers
SOURCE: Procom fireplaces
Empire makes a wall heater that is direct-vent that looks similar to vent- free wall heaters. Here is a link to a website that sells their products... http://www.mastersalesonline.com/empire/index.html. I am not sure of the prices you will need to call the on-line store. I hope this helps you.
Posted on Jun 09, 2009
Anonymous
  • 22 Answers
SOURCE: convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Posted on Sep 15, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I have a ProCom FBN400TYLA vent free natural gas
Found the manual on line and copied directly from it:
WARNING
Models FBN400 are equipped for Natural
gas. Field conversion is not
permitted.
Models FBL400 are equipped for Propane
gas. Field conversion is not permitted
This should answer your question.
See if you can run the gas line or find someone to do it cheaper for you.
Posted on Nov 15, 2009
I have a procom ventless fireplace heater and the pilot light will not stay lit
Sounds lie you need to replace the bimetallic strip by the pilot light. If that is bad the main gas nor the pilot will stay on.
Jan 03, 2016 | Procom Heating & Cooling
How do I resync my ProCom remote with my ProCom Vent Free Fireplace? I have an older model, SSU320RHL-GB.
I ran into this same problem yesterday while I was trying to get my used unit up and functioning.
If you don't switch from pilot to off and wait about a minute before turning it to the "electric" mode, the remote will NOT light the unit.
Oct 24, 2014 | Procom SSU320RHN-GB Heater
Procom pilot light wont light
Make sure the gas valve is on. The thermocouple may need to be cleaned in order for the pilot to stay lit.
Nov 26, 2013 | Procom Heating & Cooling
Cant start gas fireplace
  • Find the remote's receiver under the fireplace.
  • There should be a switch to change from "remote" to "ON".
  • Turn the switch to "ON", if the fireplace ignites, you may need to re synchronize your remote. If it does not, your remote control may be bad.
  • Bypass the remote to ensure your fireplace is operational by connecting the "TH" and "TP/TH" terminals on the valve with a wire or paperclip. If the fireplace lights up fine, then it is for sure a bad remote.
  • Universal gas fireplace remotes can be found HERE.
Oct 28, 2012 | Empire Comfort Systems Empire Tahoe...
Where can i find a downloadable user guide,and a service manual for this model..also im tryig to find the right regulator for this model..does anyone know where i can find it??thanks!!
Here's a link to the Procom Owner's Manual website. However, the Model Number you listed doe not sound like a Procom Model #.
http://www.worldmkting.com/owners_manuals.htm
Also, all vent-free heaters, fireplaces, gas log sets, etc come with the regulator built-in. Are you trying to replace one you think doesn't work? Or are you trying to convert it from one gas type to another?
If it's the latter, there is no conversion approved for vent-free gas appliances. Plus, if you could, it would take more than just the regulator to do it. Totally unsafe to do.. Please don't attempt it.
Feb 25, 2011 | Procom SN400TYL Heater
I have a ProCom Ventless Fireplace. LP Sometime
that shouldnt matter u probably have a runner tube where the gas runs from burner to burner sometimes they get clogged or spiders can build webs in them ur best bet is to turn the gas off take apart and clean tat should solve ur problem
Feb 26, 2010 | Procom ML300TBA Heater
I have a ProCom FBN400TYLA vent free natural gas fireplace and want to convert to propane because the gas company wants too much money to hook up a line. Is this even possible?
WARNING
permitted.
Nov 15, 2009 | Procom QL300TYLA Heater
Procom fireplaces
Jul 08, 2008 | Procom ML300TBA Heater
Heating & Cooling Logo
67 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
john h
Bryan Wilson
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
