Question about Westinghouse Televison & Video
Need channel access code for westinghouse tv model cw40t2rw
6ya staff
SOURCE:
Anonymous
SOURCE: wHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Posted on Feb 03, 2009
pabloloco
Paul Sager
  • 2335 Answers
SOURCE: living soluttion codes for my westinghouse tv
The remote codes for a Jumbo Remote Control and a Westinghouse TV are 097, 100, 130, and 155.
Posted on Oct 16, 2009
pabloloco
Paul Sager
  • 2335 Answers
SOURCE: codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
hi
SOURCE: need tv codes to program direct tv remote. \r\nI
Try these codes:070,085,001,126,166,079,120 I hope that helps.
Posted on Apr 17, 2011
gopakumarg43
  • 76171 Answers
SOURCE: Access code for westinghouse tv model LD-2240 serial 6616121307447
You're asking about its service mode code I assumes, and posts this solution. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now
Posted on Sep 14, 2012
I need a channel access code for a Westinghouse model VR5535Z
try this...
Contact westinghouse Channel Access Service by:
web: www.westinghousedigital.com/support;
select Channel Access and enter Access info.
Text Message: Text Tuner to 95495
Phone:1-800-701-0680 follow instructions
Jan 22, 2018 | Westinghouse Televison & Video
C?digo de acceso de canales tv CW40T2RW numero de serie.**********233
Necesito codigo de acceso tv cw40t2rw serie 6200248101704 para codigo de acceso a canales
Feb 03, 2017 | Televison & Video
I need a channel access code to set up my tv.
here is the number to call to get a code,
Jan 19, 2015 | Televison & Video
HOW CAN I HAVE THE ACTIVATION CODE FOR A WESTINGHOUSE TV MODEL CW46T6DW
Try 0000. That I hear works.unless you're using with comcast or cable box, If that's the case let me know. I have a solution there too. Just alot to type right now..hope this helps.
Dec 16, 2014 | Westinghouse Televison & Video
Need remote code for CW40T2RW
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 22, 2014 | Westinghouse Televison & Video
Westinghouse cw40t2rw. installed new main board & now picture is upside down. Is there a service menu function cure this and if so how do I access it
That is a vertical problem turn the yoke around or switch the vertical wire and that will solve the upside down picture
Feb 13, 2014 | Sceptre X37sv-Naga 37 in. LCD Television
Needing the channel access code for a westinghouse tv model DW39F1Y1 serial number 7532V33500473
I need Code the Channel Access, WestingHouse Tv
Modelo: DW39F1Y1
N?mero De Serie: 7531V34300250
Jan 04, 2014 | Televison & Video
Eldft406 tv is popping and no sound is coming out.
What is popping? Do you hear popping from the speakers or the back of the TV? You could have a serious issue on the power supply of the TV making this sound. Below is a link to the power supply for that TV.
http://www.tristatemodule.com/p-26991-lk-pi400112z-westinghouse-tv-module-power-supply-cqc04001011196-eldft406-cw40t2rw.aspx
Nov 04, 2013 | Element Electronics Televison & Video
I had cable took off and now i want just basic tv the regular channels abc, nbc, cbs and fox but when i try to scan the channels its asking me for a 5 digits access code for the westinghouse
you can go online and get the code. for some reason you have to go to westinghouse website and put in your model serial number abd it will give you a code allowing your tv to pick up local tv channels i dont know the reasong behind this
Dec 18, 2012 | Westinghouse " 40"" Class - LCD - 1080p -...
Televison & Video Logo
27 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
