Question about Samsung Washing Machines
My samsung WA7584C1 toploader won't wash and it spins the clothes only halve way
6ya staff
SOURCE:
marley mcelhinney
  • 490 Answers
SOURCE: I have a samsung toploader washing machine and
thats either from tissues left in the pockets of pants or you arnt emptying the lint filters each time you use it
Posted on Nov 02, 2009
caroldon
  • 17130 Answers
SOURCE: the tub of my toploading washing machine leans to
The suspension springs have gone out of alignment or the tub holding mechanism is shifted. look throught the bottom to see the fault in the suspension. correct on the mountings.
Even a leaning can come if the motor suspension is out of alignment.This must be centered in and the top door will close evenly.
Posted on Sep 01, 2010
shaun taylor
  • 1527 Answers
SOURCE: samsung washing machine wa7584c1 power is
hello check the belt first to see if it's come off or snaped if ok then the fault could be the brushes on the motor 2 plastic blocks sit either side of the motor they wear down can cause the motor to stop working they just slide out hope it helps
regards
shaun
Posted on Mar 13, 2011
David Boland
  • 13 Answers
SOURCE: My clothes are wet after
check the brushes on you motor
Posted on May 12, 2011
tshirtgirl10
  • 70 Answers
SOURCE: My samsung automatic washing machine wa7584c1 is
I noticed that your problem is of a washer machine, but you categorized it as a shoe problem. A simple solution to this is to change the category so the right expert can see it and hopefully answer it. I tell you this solution to help you get the right answer to your question. Hopefully this was useful, have a nice day.
Posted on Jun 16, 2011
Samsung toploader,WA13U7 does not pump or spin. When manually put on spin only, only the bottom plate spins and not the sides of the drum
firstly if it has water in it at the spin cycle it wont spin,water remaining is due to a blocked or faulty pump it doesnt take much to jam them
Jan 21, 2018 | Samsung Washing Machines
WHY AREMY POWER BUTTON NOT COME ON WHEN PRESS
www.samsung.com/in/consumer/.../washing-machin...
www.samsung.com/in/info/contactus.html
Sep 08, 2014 | Washing Machines
Samsung washing machine wa7584c1 power is on, programming seems fine, push start and nothing happens,except water flows ok, no washing no spinning no draining
regards
shaun
Mar 13, 2011 | Washing Machines
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
https://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
https://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
Manf# MAV5000AWW My toploading washing machine goes through all cycles but the last spin cycle the clothes are still soaked and i have to sring the excess water out by hand
If the machine is not pumping out completely, it could mean a blocked drain hose or a faulty/blocked pump. This would explain wet clothes However if the mache is not actually spinning it will leave the clothes wet,as well. Check and ascertain which function is not working.........Nomess
Apr 17, 2010 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Samsung Washing Machines Experts
Paul
Eric Rotmil
Eric Rotmil
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
