Question about GE Washing Machines
Ge Hydrowave washer has a steady red light. I have all the error codes written down but no error code for a steady red light. Does anyone know what this means
6ya staff
SOURCE:
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: Error Code E1
got a model #
Posted on Sep 02, 2007
Anonymous
SOURCE: AFFINITY ERROR CODE
door not close
Posted on Sep 09, 2007
Anonymous
  • 17 Answers
SOURCE: error code A21
A21 Home Error refers to the printhead not moving. Most cases, it is due to the fuse being blown on the main logic board. You have to remove the top cover. Open the clear cover, pop out the plastic pins, remove, then pull off the tractor knob on the right, remove the two screws at the top back of the printer, lift up the cover from the back towards the front. You will have to unplug an electrical connect ribbon from behind the control panel. Check the fuse and replace if necessary.
Posted on Mar 25, 2008
Anonymous
  • 276 Answers
SOURCE: error code ddo
the dispenser drawer has a magnet in it that has to line up with a sensor. if you can put the drawer back in that will solve the problem. if the magnet isn't lost.
Posted on Nov 18, 2008
wunderlichma
SOURCE: Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Posted on Jan 16, 2011
GE Hydrowave top loading washer is leaking around the top side and back of unit when filling.
check for the water outlet from the water solenoid control valve
it may be displaced or broken and not directing water to the bowl
Sep 29, 2016 | GE GTWN4250MWS 27" Top-Load Washer, 3.7...
How do i find the error codes for a wpre6150k2wt?
Hello, Here is the website for repair manual with error codes to download you are looking for: HydroWave GE Washer Repair Guide
May 25, 2014 | GE Washing Machines
My Ge Top load washer will not power up start button?,no lights.
Their is a fuse in the harness red wire that runs down from the control to the motor on the hydrowave washer. Hydrowave washer manual
Of course if yours isn't a hydrowave maybe you oughta post a model number. GE has several different styles.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 09, 2013 | Washing Machines
Error code 4 on a ge hydrowave
There should be a double digit error code.
Oct 15, 2012 | GE WCCD2050JWC Top Load Washers
GE hydro wave won't agitate
HYDROWAVE SERVICE MANUAL
Read this first then let me know your status
Jul 17, 2012 | GE WBSR3140DW Top Load Washer
My ge washer model wjsr4160g1ww will not spin or aggitate
A lot of times when that type GE Hydrowave washer does not spin/agitate it can simply be resolved by resetting the motor control board. This tip i wrote explains how to reset the motor inverter board and see if that resolves the problem with the washer. https://www1.fixya.com/support/r10292912-will_ge_hotpiont_top_load_washer_not
If ya try restting it and it does not work watch at the little green light on that motor board and see how many times in a row it blinks and reply with that number of times it flashes and i will tell ya what error code is being displayed
GENE
Oct 23, 2011 | Washing Machines
GE Profile Hydrowave Model # WPRE6100G1WT Washer fills then never washes goes thru the cycle will drain better never spins. The inline fuse is ok. No light on the inverter to check codes. Is the motor...
It COULD be the motor but it could also be a number of causes such as wiring, control PCB etc.
Draining is carried out by a separate motor. I fear a service call is required to investigate and diagnose, sorry ;-0(
Good luck,
John C
Mar 12, 2011 | GE Washing Machines
All the lights light up, but washer won't fill when I push the start button. It is barely 3 years old. This happened before and then after I left it a while, when I pushed start it filled. I tried...
Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. You may need to do it several times before it resets. After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.
GE Hydrowave notes
Feb 10, 2011 | GE WWSE5240G
The washer is only 1.5 years old and has been working fine until a recent power outage. After the poer was restored, the spin cycle quit working. Any suggestions?
Reset the motor is what you must do.
To Reset the Inverter Board: Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
Hydrowave Repair Notes
Nov 15, 2010 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
37 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
