Question about Samsung Refrigerators
33 error on samsung refrigerator - Samsung Refrigerators
Samsung Refrigerators has a code 33 E
33e is the icemaker fill tube heater error. It keeps the tube slightly warm to prevent it from freezing. You would need to remove the icemaker and there is a 1/2" or a 5/8" tube with I believe a yellow wire wrapped around it. That is the heater. Without a model# I can't be of more help
Apr 08, 2018 | Samsung Refrigerators
Error code samsung refrigerator
That sounds like a power glitch. Try pressing and holding the power freeze and power cool buttons at the same time for about 8 to 13 seconds and see if it clears. If not try unplugging for a few minutes. If it still doesn't clear, you may need to call a repair technician.
Jun 16, 2017 | Samsung Computers & Internet
Samsung rt323ted has 33. E flashing on door after power outage and I forgot how to get rid of it. Can you help?
Samsung refrigerator giving error code 33E means the water fill tube heater for the ice maker is loose or faulty.
Pull the ice maker out and check it.
Jan 03, 2017 | Samsung Refrigerators
I have a Samsung refrigerator model RF323TEDBSR that after power outage is flashing 33 E. I have tried unplugging and replugging & pressing power freeze & power cool at same time, still nothing.help?
The 33E error can indicate a problem with the ice maker water fill tube heater. (This makes sure that ice doesn't form and cause the fill tube to break.) To attempt to reset the error, press and hold the Energy Saver and Lighting keys on the touch pad for 8+ seconds. These are the top buttons on each side of the temperature display.
If that reset doesn't help, you need to replace the left door. That is available here: http://www.searspartsdirect.com/model-number/rf323tedbsraa0001/1482/0161000.html . It's part 1.
I hope this helps.
Aug 21, 2016 | Samsung Refrigerators
Manual available?
SAMSUNG RS261MDRS/XAA USER MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > RS261MDRS/XAA
Samsung side-by-side refrigerator service manual (33 pages). Refrigerator ... 26 cu.ft. french door refrigerator rf267aebp user manual (ver.0.4) (44 pages).
Samsung - RS261MDRS - 26.0 cu. ft. Side-by-Side ...
www.searsoutlet.com > Refrigerators & Freezers
Rating: 4 - ‎228 reviews
Side-by-Side Refrigerator - Stainless Steel (RS261MDRS) at Sears Outlet today! ...Overview; Specifications; Manual & Warranty; Reviews ... 26 cu. ft. for greater space, convenience and access - Spacious enough to fit about 19 bags of ...
Jan 12, 2016 | Samsung Rs261mdrs 26 Cu. Ft. Sxs...
How do I reset blinking code, 33 E, on Samsung French door fridge after power outage?
33 E code, hold energy saver button and the lighting button at the same time for 6 to 10 seconds
Oct 13, 2014 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Error code 33 and 3 for modelrf261beaesp
In your owners manual,there should
be a diagnostic section, for trouble codes
They won't go away, or fix anything unplugging it
If it did, we wouldn't need these 2,000 silly motor vehicle
questions every week
Oct 04, 2014 | Samsung RF265AA Bottom Freezer French Door...
RFG298HDRS/XAA error code 33 E FRIG SEEMS TO WORK FINE CONTROL PANEL IS NON RESPONSIVE TO INPUT
E-33 The initial value of HEX is under "14" for 30 seconds while
a weight sensor in operation.
Nov 27, 2012 | Samsung RFG298HDRS 29 cu. ft. French Door...
On the refer side we are getting a temp. reading of 67 degrees at the top as you go down it gets cooler to were in the crispers it is 33 degrees, have changed the thermistor and the evap fan motor what...
It could be a problem with the air damper but.... I doubt it.
Down load this manual and go to page 29 of the pdf file,
http://www.servicematters.com/maytag_library/docs/SAM0074.pdf
You will see this:
Self-Diagnostics in the normal operation
2-1) To select this function, press Power Freeze and Power Cool buttons simultaneously for 8 seconds with an audible
tone.
2-2) In the self diagnostic mode, only corresponding LED segments will be illuminated (see the check list on the next
page)
2-3) After a 30 second illumination of error signal, the system will return to the normal operation.
Note the position of the LED in the temp windows and the side that it appears on. Then see the Control panel LED legend along with the corresponding position legend listed below listed on page 30 for interpetation. This should tell you what has failed.
Make sure to read the Details of each failure on page 30 also.
This is the legend.
NO Error
01 ICE MAKER SENSOR
02 REFRIGERATOR SENSOR
03 REFRIGERATOR DEFROST SENSOR
04 REFRIGERATOR FAN ERROR
05 ICE MAKER function error
06 CoolSelect ZoneTM SENSOR
07 REFRIGERATOR DEFROST ERROR
08 EXIT-SENSOR
09 FREEZER SENSOR
10 FREEZER DEFROST ERROR
11 FREEZER FAN ERROR
12 CONDENSER FAN ERROR
13 FREEZER DEFROST ERROR
Run the test and let me know what the test indicated.
Thanks for choosing FixYa.
Kelly
Sep 29, 2010 | Samsung 26 Cu. Ft. Side-by-Side...
Refrigerators Logo
57 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
