Cell Phones Logo
Online Free Service Posted on Oct 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How To Logout sprint +1{888.348.1833} sprint Phone NumBer
Not Me
Level 3:
  • Sprint Master 3,158 Answers
  • Posted on Oct 20, 2019
Not Me
Sprint Master
Level 3:
Answers
3158
Questions
0
Helped
163753
Points
31816
Warning SCAM - DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
How do i fix my sprint zte phone that has an error code of 'mip 67 ??
"Try checking your SIM card number, make sure it matches with what Sprint has,i had the same issue no 4g and the error you were mentioning. My SIM card number was different then what Sprint had, they just updated the number i gave them and works awesome."
4helpful
3answers
How do I set up voicemail
Usually, all you have to do is call your cell phone number and then you will be prompted to set up your voicemail out-going message, etc
If you are unsure, the best thing to do is, on a secondary phone that is not your cell phone that you want to set up the voicemail, call your cellular service customer support number. This number might be on your cellular bill. They can help walk you through setting it up step by step since each type of phone and phone service is different.
Tutorials by Cellular Service:
AT&T Wireless Visual Basic Voicemail
http://www.att.com/esupport/article.html#!/wireless/KM1009152
Sprint Wireless Basic Voicemail
http://support.sprint.com/support/article/Set-up-and-access-voicemail-on-my-Sprint-Phone-Connect/case-gz982789-20111213-115609#!/
T-Mobile Wireless Basic Voicemail
https://support.t-mobile.com/docs/DOC-1171
Verizon Wireless Visual Basic Voicemail
http://www.verizonwireless.com/support/knowledge-base-14613/
in the US, the major cellular companies are:
AT&T Wireless Customer Support: 1-800-331-0500
Sprint Wireless Customer Support: 1-888-211-4727
T-Mobile Wireless Customer Support: 1-877-453-1304
Verizon Wireless Customer Support: 1-800-922-0204
What is the msl code number
You'll have to contact Sprint for this number. It is unique per phone. You may also log on to your Sprint account and imput the MEID. It may tell you what the MSL code is. It is a 6 digit number.
Mark
Motorola Support
Find serial number on sprint LG rumor touch
Just bring keypad up and dial *#06# and it will show your imei/serial number.
1helpful
I am getting unable to locate video....p15 error ..bitbop blames sprint...sprint blames bitbop..any ideas?
Are you using a Sprint Evo with this software 3.70.651.1.
I am not able to stream shows on my Sprint Evo phone
Sprint released a 3.70.651.1 update to EVO phones which has caused some streaming problems with the Bitbop application.
This is easily fixed with Sprint's assistance.
If you call Sprint customer service (from a phone other than your EVO) they will walk you through the steps to reconfigure the handset properly.
Sprint's phone number is: 1-877-639-8351.
When someone call my phone doesnt ring
Try and make a call out; if that works, then contact Sprint directly, as there must be some sort of issue on their end about not having your number configured correctly.
If you can't call out or get calls, check to make sure you have signal (duh). Next, turn off your phone and make sure that your SIM card is inserted correctly by removing the cover to the battery compartment of your phone and looking for a card that looks like this: benharris5.jpg If you can't find one of these in the phone, check your original packaging for such a card; it must be inserted correctly in order for the phone to do anything. (This card essentially tells the phone what phone number it needs to listen to and on what network; without it, it has no idea what to do.) If you can't find a card, contact Sprint and they will send you a new one for free/cheap.
If both of those fail, either (a) you have a defective phone, or (b) Sprint hasn't activated your phone. In either case, you'll need to contact someone from Sprint about the problem. I suggest going to your local Sprint store and asking them for help; usually you can get things done a lot faster in person. If you can't do that, try contacting Sprint directly.
Contact info for Sprint: 888-211-4727 http://www.sprint.com/contactus/
2helpful
I have a treo 755p sprint phone. I also own a sprint blackberry that I would like to maybe use my blackberry which is new. I can not locate the sim card to try to move it to the new phone. I am not a...
SPRINT DOESNT USE SIM CARDS ON THEIR PHONES THEY ARE CDMA (Code Division Multiple Access) AND IS NOT GSM LIKE ATT AND TMOBILE, YOU NEED TO CALL SPRINT AND PHONE SWAP THE ESN (ELECTRONIC SERIAL NUMBER) NUMBER UNDER THE BATERRY AND GIVE THE ESN TO SPRINT.
SORRY
2answers
How do I remove my phone number from a Samsung SPH-M500 phone?
When the new person takes over the phone, they put their new sim card in which contains the new phone number. That will then change any phone number currently in the device.
Programming sprint pcs sanyo 8200 with my sprint pcs number
just call sprint and tell the rep you need to reactivate your old phone. (charge it before calling)
Top Sprint Cell Phones Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
