Televison & Video Logo
s
sanjay sharma Posted on Oct 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio led has sound but no picture. the power o /of light flash 16 times.
Redacted
Level 2:
Habit-Forming:
  • Expert 91 Answers
  • Posted on Mar 27, 2020
Redacted
Expert
Level 2:
Habit-Forming:
Answers
91
Questions
0
Helped
35175
Points
223
Maybe the LED screen has gone out. Try to test it and see if you can change the input and see if anything comes up on the screen.
5 Related Answers
Anonymous
  • 6966 Answers
  • Posted on Aug 26, 2007
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Anonymous
  • 252 Answers
  • Posted on Oct 14, 2008
SOURCE: Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Anonymous
  • Posted on Jan 22, 2009
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
ginko
Ginko
  • 19396 Answers
  • Posted on May 04, 2009
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
B52Tony
Tony Nguyen
  • 96 Answers
  • Posted on May 20, 2009
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Vizio 55inch sound but no picture
Hi Sanjay sharma, so you comment, your Vizio TV, has problems with the backlight system and the power supply
Hola Sanjay sharma, por lo que comentas, tu TV Vizio, tiene problemas en el sistema de iluminaci?n trasera y la fuente de alimentaci?n
https://support.vizio.com/s/article/P552ui-B2-Model-Information
https://electropartsonline.com/vizio-55-p552ui-b2-lwjjrnaq-056-04245-6031-power-supply-board-unit
Vizio model E500d-AO has sound and picture, but back lighting is turning off on. How do i figure out the wrong with back lighting?
You have at least one lamp in the panel that is shorted and shutting down the LED driver in the power supply, you will need to open the front of the panel up to find the bad lamps and change them to fix it, its generally not a job you want to do unless you have some technical experience as its easy to destroy the panel
2answers
I have a vizio 470-a0 that is dark and the back light blinks every 5 seconds
The front LED light that shows whether the TV is on or off will flash so many ... press and hold the power button for 5 seconds upon plugging the TV in. ... The flashing code I got meant the power supply was bad.
How do I fix my VIZIO TV?
Vizio TV Repair - Instructables
www.instructables.com/id/Vizio-TV-Repair/
InstructablesSo my Vizio TV was flashing on & off rapidly every time I switched it on. ... good way to get something to work, but it got things working until I had time to repair it.
Fix Power Problems In 5 Easy Steps: What To Do When ...
vizhdtv.com/fix-power-problems-in-5-easy-steps-what-to-do-when-your...
Aug 26, 2015 - Vizio TV power cord plugging into a power outlet. Do you know ... Powerproblems might require service or replacing parts inside the TV. Before ...
Vizio p50hdtv10a led light blinks 10 times when powered off
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
