Question about Sony Televison & Video
I recently got a Sony Trinitron CRT to play my old games on. I noticed all of the av ports the sound was working but there was no picture. But the component cables worked perfectly fine. I was fiddling around with the hidden service settings and I managed to get a picture. So I decided to reset the settings on the tv and now I can't change back to my input channels
6ya staff
SOURCE:
Bill Heronemus
  • 308 Answers
SOURCE: sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Posted on Dec 24, 2006
Anonymous
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
Anonymous
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
MrBob84
Robert Jones
  • 90 Answers
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Posted on Feb 13, 2008
micromaster
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
Picture has horizontal lines when game console is connected to composite input.
use the remote for the TV to select the right channel i.e.. AV / HDMI / VGA etc.. as alot of tv's don't auto detect game consoles.
if no joy check your cables.
Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony trinitron kv-32fs10 component color problem
check the av in puts of your tv, this sounds that your av jack has a loose joint on the connection under.
May 24, 2010 | Sony KV-32FS10 32" TV
TV has no picture, but sound works fine
Are you using the AV input for the XBox or other cable? If you use AV, then use the same input that the Xbox does not show picture, plug in a DVD and see if it works. If it does not have a picture, so 100% your TV has problem.
Aug 11, 2009 | Sony Televison & Video
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Color adjustment on Sony 36" Trinitron
Unfortunately, the CRT (Picture Tube) is reaching its very end. Your set is not feasible to service even if the CRT would still be available from Sony or any jobbers.
I would be seriously shopping for a new TV set!
Jerry G.
Oct 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
NO picture
You didn't say how old your set is, but if it has a picture tube, then this may be you trouble. I've seen several Sony's do this. I've had several come in to the shop and set and play for several days and then "wink" out! Sometimes, though, the high voltage circiut will shut down and the sound will still work. I would advise you to have it checked at a shop. If is very old you need to get an estimate. Stargazer
Feb 05, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
19 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
