Hi, okay sounds like a faulty wig wag( throttle pot ) that is connected to the lever that makes your scooter go forward or backwards, try gently pushing in the upwards direction as you push the lever , or pulling down as you pushed the lever forward, what you 're doing is seeing if the tracks within the wigwag pot or worn by moving the lever in the up and down position you are making a good connection again.
Regards
Rob
SOURCE: ajust speed
Yes, Unfortunately it is a technical solution, the twist grip speed control is a potentiometer (variable resistor) other then limited the amount the twist grip is turned , the only other way to limit the speed is to add a fixed resistor to the "top" end of the "pot", lets say you want a 10% reduction and you have a 1000 ohm pot you would add a 100 resistor to the "top" of the pot, if it doesnt work correctly change the connection to the other endof the pot
SOURCE: Rally PRIDE 3-WHEEL SCOOTER
Sounds like you have a bad throttle pot. You`ll need to check the resistance on it or take it to a dealer.
SOURCE: Mayfair freerider mobility scooter - keeps losing
ok, sounds like the speed pot,
Can you move the throttle lever up and down, try going along at a constant speed (losing power ?) then move the lever up & down ?
does it improve response ? if so replace the speed pot.
Regards
GeWiz.
SOURCE: When moving at top speed, my scooter hesitates at
hi, that is a textbook problem related to the speed controller pot,
the pot is attached to the lever you move to go forward etc,
to be 100% certain trying moving the lever in the upwards direction while gong forward ? does it speed up ,a new speed pot required.
Regards
GeWiz.
