Hi, make sure the freewheel lever engaged, so you can't move the scooter, turn it off and on, ?
Check the motor brushes making sure they can be removed easily if not that's the issue , refit them, taking care not to crack the brush caps.
Wig wag or called a throttle lever ,is it loose ? .
At worse it a controller fault ...
Regards
Rob
Gewizrepairs.co.uk
SOURCE: shoprider cadiz scooter, batteries show full
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
SOURCE: Hi I have a shoprider cadiz .. when i try using
your throttle pot needs replacing. your thumb lever attaches to the throttle pot.
Testimonial: "Wonderful information Thank you ..before i read your answer i sprayed the throttle pot as you call it with switch cleaner Been great since .. "
