Electric company shut down electricity on our street. this cause an error on our Maytag Maxina.
I don't know what it means but you can try to reset the control panel by unplugging it for 10 minutes then plugging it back in. This may or may not help but it works every time my dryer gets stuck on or off with the panel display showing something odd, or stuck on so many minutes left but it doesn't ever stop. It won't cost you anything to try this. If it happens very often you may need the panel replaced.
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
SOURCE: Fl error on washer
Hello there :
I am hoping that i am reading this right it looks like you said a fl error right and if so please read this whole solution that i have provided below
FL
Flood Condition
FL
flashes
if any overfill condition occurs. This condition
occurs
when excessive water in the tub causes the
overfill switch
to trip. The control must realize that the trip
was due
to an overfill condition instead of a suds lack
condition
in order for FL to be displayed
With an overfill condition, the beeper repeats a
warning
every 10 seconds with no time-out. The pump is
cycled in
drain mode for 30 seconds on, 30 seconds off until
the overfill
switch resets or power is discontinued to the
unit.
Press STOP/CANCEL to clear the display.
If this condition continues have the machines water level switch replaced or repaired
Hope this is very helpful for you
Best regards Michael
SOURCE: Kenmore HE4-t washer stops and gives F06 code and warning sound
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: i get an f06 and
F6
code is an issue with the motor drive tachometer.
Most often this is caused
by poor connections at the machine control or motor controller. Locate
the main machine control by removing the top panel and the motor control
by removing the rear panel. Remove each connector, one at time, and
reinstall. If this does not work, you likely have a faulty control.
E1
means that the thermistor is open and needs to be replaced.
The connections can be loose but the most likely cause of an E1 error is
a bad thermistor.
If you're comfortable and confident in your
do-it-yourself skills and have access to a volt/ohm meter you can check
and replace this part yourself.
For replacement parts - head on
over to SearsPartsDirect.com - PartSelect.com - or RepairClinic.com and
enter in your full model number for a full parts listing.
Hope helps.
SOURCE: I have a whirlpool duet steam and reads codes F06
OK your almost there. The switch or Latch that locks the door is faulty or bad. It is either that or probably not connected to the right terminal. New control board!!! That was expensive! Good luck!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
