Question about Toshiba Televison & Video
My Toshiba tv screen went black and no power. . ., this was sudden..New TV only using it for 3 months. What to troubleshoot
I have unplugged everything and left for 30 minutes then reattached; reset modem, changed batteries in remote, used the manual power button on side of TV, checked the outlet for power, checked the fue box. Bell receiver has power as the lights are on.
    Top Expert:
  • Toshiba Master
  • 66,248 Answers
CONTACT THE PLACE YOU BOUGHT IT FROM YOU HAVE WARRANTY USE IT
Posted on Oct 20, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
pcland_com
SOURCE: Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Posted on Mar 24, 2008
Anonymous
SOURCE: 37LC7D, screen blank, cannot power off manually or w/remote
Hi, I would buy your TV
Posted on Dec 14, 2008
Steve Yocum
  • 668 Answers
SOURCE: Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
Posted on Jun 23, 2009
Anonymous
SOURCE: Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Posted on Oct 25, 2009
Loss of picture
Inverter board has failed. You can get replacement inverter by contacting the people over at www.tvcircuitboards.com
Jan 01, 2013 | Televison & Video
Hi,Iwas watching TV and the screen went black.No lights on,I unplugged and plugged again but anything happened. My TV is a Toshiba Regza model 42RV530U. Can you help me? Thanks
If there was a popping noise of any kind when the tv screen went black there's a high possibility that one of the fuses in the tv popped and there is no power to the tv. It could also just be the outlet itself and try plugging the tv to different working outlets.
May 24, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Screen black - Suddenly went black screen with no picture, no sound and no menu access. Power light is on. Only 18 months old. Have tried unplugging for 1 hour to reset to no avail. Any ideas?
I had issues start around 15 months - the unit would freeze up, or change channels spontaneously, or turn on and off at random. So far we've not any permanent solutions. The best we've got is to lock the control panel out (which didn't keep it from turning on and off) after which we tried resetting to factory defaults. I've emailed the company and am awaiting a reply.
Something like you describe sounds like a fuse issue or something else after the power supply.
Jun 13, 2010 | Toshiba 40RV525U 40 in. LCD TV
Picture went black during viewing and won't return
its looks ur screen is DEATH.........as u only have the set for 18 months i assume u have no warrentie left'
may go in touch with TOSHIBA and tell them ur problem u have......
but it looks to me u need a new screen,,,,,or may a service will solve ur problem,,,,,it may cost u .......but may cheaper as a new screen
Nov 20, 2009 | Televison & Video
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
We just purcased Toshiba 26AV502U, now the screen is blank
Heard back from Toshiba. They said to unplug the TV, wait at least 3 minutes, and then plug it back in. This should allow it to reset itself. Sounded too simple, but after doing just that the tv has worked fine for the last three days! Toshiba noted that if this didn't resolve the problem we should contact them to have a Toshiba Authorized service person come check out the tv. It worked for us, hopefully it'll work for you too. Good Luck
Jan 18, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Toshiba 46H84 turning off by itself AND all BLUE screen with Black Dot in Center
Try to replug everything in the TV. Before you turn it on. make sure all plugs in the TV to the wall is plug in tight. When you turn your TV on hold the power button down to see if it resets
Feb 28, 2017 | Toshiba 46H84 46" Rear Projection...
Prima q2716ss
WE took our T.V. to Gragal Electronics in Waterloo, On. and he was able to reset the settings within the tv and it only cost us $81.36 to have it fixed. Apparently other remotes can go in and corrupt the saved settings, which messes up your tv.
Mar 24, 2008 | Prima CV2011 TV
Toshiba Plasma TV Green and Pink (Diffusion?) Problem
I could be wrong but sounds like your plasma display is going bad. What is your model number?
Dec 28, 2007 | Toshiba 42HP66 42 in. LCD Television
Televison & Video Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
