I checked the drain hose to the garbage disposal and it was clogged I then pulled out the Asko D3232 filters and cleaned off the gunk, thought i was good so flipped the breaker and still stuck on drain mode. Strangely when it is pulled away from the wall it will shut off and run properly but when I push it back into the hole in the counter the drain starts up again....so it works only when pulled away from the wall
When the pump runs continuerly it is probably water in the bottom of the dishwasher, when you drag it out on the floor you can try to flip it to see if any water will run out of the mashine, or you an take the bottom front of to see if you can see any water, there should be a water float in the bottom that is being activatet by the water that can leak from the washing cabinet to the bottom of the dishwasher.
SOURCE: Kenmore Ultra Wash III Dishwasher will not drain properly
From the sound of things, your dishwasher drains faster than your sink drain ( via the garbage disposal) can drain it off.. You may have a problem with the way your sink drain/trap is vented and there is too much back pressure to drain down quickly.. When you run water from your sink, does it take a long time to drain down or if you fill your sink up and drain it, does it drain slowly ? That may be your problem.. Hope that helps.
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
SOURCE: How do you clean out a clogged drain hose from the
You may have to pull the dishwasher out and remove the clamp on the hose from the pump. run a snake or a coat hanger or anything else that you be long, flexible but stiff enough to move through the drain. You might be able to go from the disposal side back to the drain. This would be easier if you can. If you run water down the disposal side does it back up into the sink? If it does, then the clog is down below the disposal and not the dishwasher side.
SOURCE: My Kenmore Ultra Wash III dishwasher 665.1584990
My Kenmore Ultra Wash III won't open the water valve. The pump starts and the heater turns on, but no water. Any ideas?
SOURCE: standing water in my kenmore dishwasher after complete cycle
Hi, z
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
