Whirlpool LSQ9610L Top Load Washer Logo
Anonymous Posted on Sep 18, 2009
Whirlpool Ultimate Care II LSN300PWO Grinding/no spin/agitation
Whirlpool Ultimate Care II LSN300PWO will not spin nor agitate and makes a terrible grinding noise when turned on. All was well until I heard the noise, ran to the washer and the clothes were wet, it was suppose to be spinning and nothing was happening. It did allow me to drain the water out and I can add water, just not spin or agitate. The sound was very loud and much like the sound of grinding gears.
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on Sep 18, 2009
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2972239
Points
24702
HI. the first action is to test the lid switch. The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine. For this reason, the lid switch should never be bypassed. Aside from electrical problems, the switch may suffer from a mechanical problem. The lid may have a striker which depresses the switch when the lid is closed. Make sure the striker is functioning and aligned with the hole over the switch. Inspect the switch and make sure the metal strip is not bent out of position (if present). If your switch uses a mercury switch, make sure the mercury envelops the internal contacts when it is in the closed lid position. Your design may differ, so inspect it for proper operation before proceeding to the electrical testing.There are two primary types of lid switches. One type on which you can directly test the terminals on the switch and another style where you have to test it at the wiring harness. In either case the method for testing the switch is the same. If a wiring harness is used, separate the two pieces of the harness and test the side of the harness that connects to the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Some lid switches also have a fuse, you can visually inspect the fuse or test it for continuity with a multimeter. If the fuse is bad, replace it with one of the same rating.
If the lid switch is operational, i would move on to the next possible issue. This will be the motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission
. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
***(I would suggest to check the following while you are in the area for faults as well(((Clutch,motor,motor board,transmission))). inspect these areas thoroughly)
Ok, if all the above checks out ok and, there are no signs of damage to any of the above parts stated, this will confirm a timer control module malfunction. replace the control device(timer or control board) asap, if possible.
Testimonial: "thanks! "
Anonymous
Level 3:
Brigadier General:
  • Master 4,088 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
4088
Questions
0
Helped
1512430
Points
12435
The motor coupling has probably disintegrated. Go to: http://www.fixya.com/support/r385252_replacing_motor_coupling_W... By jsrock516 for complete instructions. Give him a pat on the back too, please.
Testimonial: "thank you!"
1helpful
Wont agitate
your dog ears are bad.
You can replace them for about $10 @ your local appliance store.
2helpful
1helpful
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
5helpful
Won't spin or agitate
coupling.between motor and gearcase.
Whirlpool Super Capacity Plus
If it doesnt agitate and makes a grinding sound replace the coupler.
Won't spin or agitate, makes grinding nois only.
Pick up a copy of the Nov."The family Handyman" magazine. Pg. 60 shows your problem and how to repair it. Most likely it's a broken coupling,
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
