SOURCE: My computer doesn't recognize my
That means that the card was installed on your computer. If so, then follow thw link below to uninstall and then reinstall the drivers.
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
SOURCE: I have a Cannon EOS
Two possible situations. It might be that the lens focusing system isn't working. Try focusing by hand (turn the lens manually) If the image moves through a point of sharp focus, then you have a lens or focus motor problem.
More likely, you have improperly adjusted the diopter. There is a small, circular wheel on the right side of the viewfinder, toward the top corner. It is sometimes covered by the rubber viewfinder hood so you might not notice it. This adjusts the diopter correction in the viewfinder and if it's set wrong, nothing will ever look in focus. The pictures would be fine, but since the diopter is a correction for your eyesight, the viewfinder will be out of focus.
SOURCE: I'm using the program Total
Welcome to Fixya. For clarification are you using the same computer that you have used for years? Do you have the same operating system? and after it stop recording and you run it again do you have error message on the screen? Have you tried using the same software to another computer and see if you have the same problem?
Please answer the questions so that we can check what seems to be the problem. If you have questions please let me know.
Thanks for using Fixya
b> Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
