Question about Sony Televison & Video
Sony g21p2 tv power on h harp lign set off stanby what poblam
4 Suggested Answers
6ya staff
SOURCE:
Jaime Hernandez
  • 2337 Answers
SOURCE: Sony KV30hs420 0 Stanby Light Timer Blinks 3 times and powers TV off
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. If you have electronic knowledge you may be able to fix it. Let me know if I could help you further.
Hope this helps.
Posted on Jan 25, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
It seems problem in BY board in your KV-34HS420 TV. this board is called DRC Engine as well. Its part number and description is ...
A-1302-942-A HBY BOARD, COMPLETE
Its available HERE and price is apporx $82.00
Hope this info will help you out.
Posted on Aug 15, 2008
shaun taylor
  • 1527 Answers
SOURCE: sony 40" tv kv-40xbr800
hello shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Posted on Dec 28, 2009
I have a sony crt tv (kv-G21P2) this tv pictures ok, but sound not working . Speaker good. Not coming any noise . Not working sound how fix this?
Check and replace damaged component/s at its audio output stage circuit. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Apr 01, 2016 | Sony Televison & Video
I just connected the main board A1727318A to Sony tv KDL-32XBR9
How many blinks do you have?
Main Power 2 Times (PS Board, G2CE Board)
DC Alert 3 Times (BM3 Board, G2CE Board)
T-Con 4 Times (T-CON Board)
HDMI 5 Times (BM3 Board)
Backlights 6 Times (Inverter Board)
Temp 7 Times (BM# Board)
HFR Error 8 Times (LCD Panel)
I hope that it will help you.
Apr 02, 2015 | Sony Televison & Video
SONY LCD SWITCHES OFF BY ITSELF
From my experience with sony tv it's normal.The set is going through update mode.Leave the set for about 10 minutes and it should be back to normal.
Jan 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony kdl-46w5100 shuts itself off then goes to stanby flashing 10 times
I have the same tv with the same problem, replace the power supply boards and still had same problem, called in a tv repair man and I was told I have a main board problem bu board Watch Dog Timer used to track micro processors, led flashing 10 times cost around $425 parts and service call
Feb 24, 2012 | Sony KDL Televison & Video
Tv is in stanby mode. when i turn on power it seems like it wants to start but nothing comes up on screen. stanby light is blinking
The problem is in the main board of the tv, it is either a power supply issue or a high voltage problem. In order to isolate you will need a tv tech to check the set out and cost involved.
Jan 07, 2011 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Why power/stanby blinks light red
how many times does it flash? The back of the manual will usually tell you what the flashes mean. Try this: unplug tv from power. While unplugged, hold the power button in on the TV, not on the remote! Hold for 10 seconds. Replug the power and try to power it up. If you get no picture, you need a repair. Contact the manufacturer for an authorized servicer.
Jul 19, 2010 | Sony KDF-E42A10 42 in. LCD Television
How do you disable the stanby timer by power
U can't stanby mode indecation power is there,for ready to go to power when power go to high voltage.
Oct 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV is in stanby/timer?
There are any number of things could be wrong here. If you have an ever so slight chirping sound coming from inside the unit when you press power could be defective crt driver Ic702 which is a Tda6108 and a common problem for these sets. Could be regulator or flyback and could even be vertical Ic which is a Tda8172 and just the way that circuit is designed, without full deflection from a failed Ic, the shutdown would keep the power off...
Best advice here is take it in to a qualified shop and have them estimate it, you'll be money and headaches ahead..
Bill
Nov 24, 2007 | Sony KV-20FV12 20" TV
Televison & Video Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
