SOURCE: 1100 wierd clutch disengage problem
Bleed your slave cylinder on the sprocket cover and refill the hydraulic fluid. If you have any leaks you will get air in the system and it will not fully disengage the clutch. As for the 750, they have cable clutches and you just need to adjust the slack of the cable.
SOURCE: ryobi gas chainsaw- chainsaw brake is stuck on. How do I release
You just have to pull the lever back, like it was on the saw, until it clicks/unlocks. It may be hard to do, but thats what has to be done.
SOURCE: 1999 Dodge Intrepid...shift lever wil shift gears
I believe that the cable has to be adjusted. Most cases, the cable adjustment is off. Worst case senario, is the bushing in tranny is worn out.
SOURCE: shoprider cadiz scooter, batteries show full
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
SOURCE: Hi I have a shoprider cadiz .. when i try using
your throttle pot needs replacing. your thumb lever attaches to the throttle pot.
Testimonial: "Wonderful information Thank you ..before i read your answer i sprayed the throttle pot as you call it with switch cleaner Been great since .. "
