Televison & Video Logo
Jack Handley Posted on Oct 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony Bravia XBR-LX900 power up problem, 5 red LED flashes but no power up, when first powering up I hear a click noise from the power board then nothing only the red flashing light.
Is there a way to confirm if it is the power board before ordering a replacement?
David Payne - Geek
Level 3:
Top Expert:
  • Sony Master 2,014 Answers
  • Posted on Oct 20, 2019
David Payne - Geek
Sony Master
Level 3:
Top Expert:
Answers
2014
Questions
0
Helped
55552
Points
545411
Testimonial: "The reply had nothing to do with my question!"
5 Related Answers
Anonymous
  • 6966 Answers
  • Posted on Aug 26, 2007
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Anonymous
  • Posted on Jan 22, 2009
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
Anonymous
  • 8197 Answers
  • Posted on Mar 12, 2009
SOURCE: PT-AE700U Lamp led flashes red
Reset the lamp hours. Here is the manual on how to reset lamp time.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and Please Rate Fixya!
Anonymous
  • 178 Answers
  • Posted on Oct 08, 2009
SOURCE: Sony KDS50A2000 power LED flashes green, then
4 blink is a fan error. This is caused by one of the three fans not spinning fast enough or has stopped completely. The fan that usually causes this error is the one over the bulb and toward the back of the set. The repair is not expensive, but to do the service correctly you must get all the dust out of the tv or the fan will clog up very fast again. Getting the dust out is kida tricky because you have to get the dust out without contaminating the light engine, if it gets contaminated you will get colored splotches on your picture. I recommend getting a pro to fix it, the repair should be fairly reasonable around $150 to do the repair. The fans are not that expensive.
Anonymous
  • 336 Answers
  • Posted on Mar 02, 2010
SOURCE: Sony bravia KDF-E50A12U rear projecion tv wont turn on
Hi it sounds like it could be an issue with board that powers the lamp ,it's called the ballast.When you put a new lamp in the ballast has to provide more power ,when it starts to go weak it will not light up.Sometimes you can put your old lamp in and will work fine.Try partstore.com they might have it right there.Hvae a blessed one!
No picture on startup , continuous flashing green and orange led
Seems that way. Fact that you saw the logo on screen eliminates the inverter board.
My brother has a 60" Sony xbr1 year 2006 and the red light blinks when you turn on but no picture or sound. Has a brand new bulb, that's not the issue.
Could be a cooling fan. Sometimes they don't start because of dust buildup. Could be worn out also. I had to replace mine once. Can order via internet.
My Sony Bravia XBR 52in will not stay on and red light is blinking.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
2answers
TV powers on with no splash screen and then powers off.
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
2helpful
I have a Sony KDL-40V4100, constantly hearing clicking noises
Could be the power board or main board defective, but I suggest you do firmware update first. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 download the software.
1helpful
SONY BRAVIA 32" XBR LCD TV KDL-V32XBR1
What about the Led, it shows blinkig light or just dead . if no blinkig at all could'be power supply fuse and or the powers upply board
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
