SOURCE: I am looking for a manual for Franklin Chef model
http://www.franklinchef.com/fc501im.html
Try this web site. This is the closest thing I could find for you about your unit. Yours may be a bit older but some things may be the same.
Good Luck
SOURCE: Magic Chef MCCF5W do not works. fast freeze is
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
SOURCE: I have a Frigidaire FFU11FK2AW 11.9 cu.ft. freezer
maybe your freezer is leaking no freon inside
SOURCE: MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door.
Just had the same problem after unboxing.
Simple, just be sure to do the entire door.
SOURCE: 20 cu ft freezer top
Gas is low, also check for air flow obstruction, this may fix it,,also seals at the base of the door....Russ
Hi David Payne my name is Darrell burke an have a problem about the proper way to wire a delta table saw model 34-720. Could please email me at [email protected] please
