Question about AMP Car Audio & Video
What are some reasons that will trigger your car radio to say amp error or would someone have had to messed with it in some way?
Never had a problem stereo played just fine until i lent out my car when i got it back it was clitching on and off than would turn on for under a minute and turn of saying amp error
    New Friend:
  • 40 Answers
Another possibility is that they might have cranked the volume up on it and blew one or more of your speakers. The voice coils could be rubbing and grounding out causing your issues.
Posted on Nov 02, 2019
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Everything depends on the car stereo and amp setup that you have. That info is very important. Um without that it's just a shot in the dark. Possible stereo settings for amp were changed, amp failure, amp wiring fault or the good old it just doesn't feel like working.
Posted on Nov 01, 2019
6ya staff
SOURCE:
Anonymous
  • 306 Answers
SOURCE: My bose car stereo system
The problem is in the power amplifier section. If you a preamp out connector you can troubleshoot using another power amp between that and the speakers but you may need a schematic to isolate to the components at fault. Bose is worth fixing and if you can remove it yourself you will save money by getting it to a bench technician, even a TV repair shop can fix it. Steve Medley
Posted on Nov 08, 2008
Anonymous
SOURCE: Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Posted on Jan 28, 2009
Anonymous
SOURCE: 2005 scion xb: pioneer stereo
All you need is a high-low converter. you just hook up the speaker wires to it. It converts to rca jacks.
Posted on Aug 15, 2009
Anonymous
SOURCE: My lexus rx 3500's stereo jammed-"error 4"
I also own a rx 330 and my car has the same error. This is a manufacture defect. Unfortunalely if your car is no longer under warranty the price to replace is approx $800. The cost for the radio is $650 and labor is $150. The lexus dealership will tell you that they won't fix it as they are unable to but they will order a new one. There are many other blogs regarding other lexus rx 330 owners who have experienced the same problem. I have been searching tirelessly to find a way to avoid paying the monies as my car is out of warranty. I have had no success. I wish you the best.
Posted on Nov 14, 2009
rusty2c
  • 239 Answers
SOURCE: clarion dxz545mp amp guard
, the message you are getting is "amp guard". This is the mesage it will display when a short in a speaker wire or speaker with low impedence is hooked to the internal amp and sends it into protect mode, shutting down the amplifier section while the rest of the unit continues to work.
check all of your speakers
Posted on Aug 19, 2010
I need the wire colers for the radio on a 2003 expedition. Someone cut them and trying to fix the radio
Radio Battery Constant 12v+ Wire: Light Green/Violet
Car Radio Accessory Switched 12v+ Wire: Pink/Light Green
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Nov 25, 2010 | Car Audio & Video
I have a 1996 chevy cavalier and I am trying to find a free wiring diagram for the audio system. The person who had this car before me messed it all up and I need to figure out what is supposed to go...
1996 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
i know u said u want a pic but you should b e able to do it from this
pls rate
Aug 16, 2010 | 1996 Chevrolet Cavalier
I need the radio wiring color codes to a 2008 dodge avenger sxt
Clarification Request Posted by emissionwiz on Mar 17, 2010 Dodge Avenger with Infinity Audio Car Radio Stereo Wiring Diagram Car Radio Battery Constant 12v+ Wire: Red Car Radio Accessory Switched 12v+ Wire: Blue Car Radio Ground Wire: Chassis Car Radio Illumination Wire: Green/Orange Car Stereo Dimmer Wire: Green/Yellow Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: White/Black Car Stereo Amplifier Location: Mounted under the rear deck. Some models have a black plastic trim covering the factory amplifier. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): White/Blue Left Front Speaker Negative Wire (-): Black/Blue Right Front Speaker Positive Wire (+): White/Red Right Front Speaker Negative Wire (-): Black/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Yellow/Blue Left Rear Speaker Negative Wire (-): Gray/Blue Right Rear Speaker Positive Wire (+): Yellow/Red
For some unknown reason your answer was changed to a clarification
Mar 17, 2010 | Car Audio & Video
Can,t figure out how to wire it up to my 1995 jeep and would like to find out how to wire it up?
Dont know what model you have so here u go!
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
1995 Jeep Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Orange
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Switched 12V+ Wire: Red/Gray
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
window.google_render_ad();
Jun 03, 2009 | Pioneer DEH-P2000 CD Player
I need to find the colors for the rear speakers to hook up a amp
2003 Mercury Sable Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Jun 02, 2009 | 2003 Mercury Sable
Need help with wires
This is from a 2004 Solara, but it's probablly the same.
2004 Toyota Solara Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Dark Green
Car Stereo Dimmer Wire: White/Green
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
May 25, 2009 | 2006 Toyota Solara
2000 mustang convertable amp problems
Are you sure the amplifiers are trashed? Have you checked the fuses? A reputable car audio shop could help for a fee of course, but it may be worth the price. It's odd that (all) the amps would malfuntion simultaniously unless someone unqualified messed with the wiring or the radio has a defective trigger wire (turns the amps on). You'll be sadly disapointed with any new radio without the factory amps, especially with the convertable ... I strongly suggest getting the amps (the factory system) working again.
Apr 17, 2009 | Metra Turbowire 70-5605
Stereo wire diagram
1995 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Switched 12v+ Wire: Blue
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Left Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Mar 25, 2009 | 1995 Nissan Sentra
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
Car Audio & Video Logo
Top AMP Car Audio & Video Experts
ANTISPAMMER
butternutts
Are you an AMP Car Audio and Video Expert? Answer questions, earn points and help others
