Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed.
Read more: http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
SOURCE: GE Profile top load washer wont drain or spin
SOUNDS LIKE THE LID SWITCH IS DEFECTIVE, ITS A SWITCH THAT CONTACTS WHEN DOOR CLOSES, THEN RELEASES CONTACT WHEN DOOR OPENS. HAVE A PRO CHECK IT AND REPLACE OR BYPASS IT.............
SOURCE: whirlpool front load washer wont drain or spin
Sounds like the pump quit working and needs replaced
SOURCE: I have water coming from the bottom. How do I take
remove the 2 bottom front panel screws-mike
SOURCE: kenmore model 110 will not start drain cycle-top load washer
If the machine agitates, you probably have a bad pump. This is pretty straightforward repair, and I'm sure I can help you if you think you can do this yourself. Follow this link to a previous explanation on cabinet removal and you will find the pump right in front of you when you get the cabinet off. The part is relatively inexpensive to obtain from a local appliance part store. Changing is very simple. Hope this helps you :)
http://www.fixya.com/support/t2827272-kenmore_washer_model_23922200_not_spin
