Question about Whirlpool Washing Machines
Whirlpool washer grinds when starting any rinse cycle and the pump was replaced under warranty but still grinds, loud sometimes
    Top Expert:
  • Whirlpool Master
  • 10,371 Answers
Check under agitator for broken cogs or bad gear
Posted on Nov 13, 2019
6ya staff
SOURCE:
mikedurland
Mike Durland
  • 481 Answers
SOURCE: Whirlpool washer Mod# TWAS750PQO, Ser# CR3520005
is it possible that the washer was overloaded? if so the agitator has little plastic "gears" that move the agitator one way only, they could have made the sound.
you can also check under the washer to see if anything (like a coat-hanger or something) is interfering with moving parts of the washer
Posted on Jun 27, 2008
mikedurland
Mike Durland
  • 481 Answers
SOURCE: Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
Posted on Jun 28, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Posted on Nov 20, 2008
    Anonymous
    • 6 Answers
    SOURCE: Water level issues on the Whirlpool washer.
    It's overfilling If your washer is overfilling, check these:
    Water-inlet valve
    Water-level switch
    Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
    Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
    It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
    The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
    If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
    Posted on May 08, 2009
    yan candie
    • 39 Answers
    SOURCE: Whirlpool washer grinding noise when draining
    there could be something in your pump.....remove the pump and see if there is not something inside...
    Posted on Jul 04, 2009
    Why does it beep through the entire. Wash cycle. No code showing.
    Whirlpool Duet GHW9150P Front Load Washer Beeping ...
    www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
    Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
    [PDF]front-loading automatic washer use and care ... - Whirlpool
    www.whirlpool.com/.../U...
    Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
    [PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
    https://www.whirlpool.co...
    Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
    Continuous Beeping - Whirlpool Duet Sport Washer - The ...
    appliantology.org > ... > The Laundry Appliance Repair Forum
    Jan 25, 2016 | Whirlpool Washing Machines
    Washer not draining
    sounds like you need to replace the pump
    Aug 30, 2017 | Whirlpool Washing Machines
    My whirlpool top loader is making a grinding
    The direct drive coupling is broken. This video will show how to replace it.
    http://appliancejunk.com/forums/index.php?topic=3437.0
    While you have it torn down check the drain pump for blockage too.
    Dec 26, 2009 | Maytag PAV2300 Top Load Washer
    Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
    Hi, Do you know if the washer spins at all?
    It sounds like the coupler has gone bad.
    Please let me know if it spins at all.
    I can send yyou instructions on changing the coupler.
    Vic
    May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
    Grinding duet ghw9150pw4 front load washer
    This is joyce
    I just had to have my barrons replaced in my washer on the spin cycle it sounded like plane taking off. I dont know about yours but mine was loud, you probl. have the same problem. get a technician to come and check it out, all these machine's are hard to work on so let professional take care of it. if you need me to find someone in your area please just let me know.
    thanks,
    joyce
    Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Washing machine will not spin
    If this is a Whirlpool washer, you have a broken motor coupler
    Jan 23, 2009 | Washing Machines
    The washer will not spin
    my washer will not finish spin and reins cycles please HELP ME
    Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Jun 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    49 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
    jimorris77
