Hi, there, Good day I have washing machine SANYO brand top load 7 kg and recently shown error ER so what is the solution can you define anyone pls. I can't used anymore coz of Error ER. Thank you. Appreciate a
6ya staff
SOURCE:
catriver
Ron Marek
  • 878 Answers
SOURCE: Washing machine error SD
cammie, it's probably an isolated problem. If you are not oversudzing then the problem would be in the spin basket binding or not able to nest when the spin is called for. This is not a common problem. It's a good deal that you are having it replaced. Usually I see a lot of these with the famous F51 code, meaning that the motor sensor is sending a false signal to the board. Let us know if your new one has the same problem...Catriver..post back.
Posted on Feb 01, 2007
jimorris77
  • 411 Answers
SOURCE: Buying a top-loading washing machine - advice needed
You are on the right track looking for a top loader. I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the machine ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video on youtube which showed me how to take my machine apart. This video (direct drive washer repair) made it possible for me to do my own repair. You probably don't have any idea of the wonderful help you can get from youtube videos. Your first stop should be at youtube. Just search for the help you need. You could search for "clothes dryer repair" or "clothes washer repair" or "dishwasher repair". If you are not able to view and/or download the videos, or after you've seen all you want to see, I suggest you go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers, dryers. and dishwashers as well as other appliances. Another excellent site is www.acmehowto.com If you have a direct drive top load washer and need help taking it apart these youtube videos are wonderful help. I was so impressed with them that when I saw all these people needing help, I wanted to tell them about the videos. If you look at the back of your top load washer and the panel is solid (no small inspection plate to remove, which would indicate you have a v-belt drive) chances are you have a direct drive and this video (direct drive washer repair) is just what you need. After you've seen all the appropiate videos, or if you have a belt drive washer, you will probably still need help in determining what the trouble is and how to fix it. I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Another excellent site for DIY help is www.acmehowto.com Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you where you can get help to solve the problem. Good luck with it.
Posted on Dec 21, 2009
Anonymous
SOURCE: hi am getting e1 error in my washing machine
what is an E1 error message
Posted on Jan 04, 2010
rickead1
Rick Ead
  • 1998 Answers
SOURCE: I HAVE BOUGHT SAMSUNGWA80V3 TOP
this error comes if waste water pipe jammed or blocked
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
check the drain pipe that comes out the back of your machine
please message me back if this does not solve your appliance situation and please remember to rank how this opinion has helped Thanks again
Rick
Posted on Nov 09, 2010
e-Guru
e-Guru
  • 3917 Answers
SOURCE: My Videocon Fully automatic top
Hi
E9 means the water level sensor is defective or the pipe connected to it is faulty.Generally error E9 means a problem with your water pressure sensor. do you have water in the tub? Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Aug 02, 2011
What is error code E57?
E57 Checksum failure Software error occurs - checksum failure. Non-recoverable error. Main control board must be replaced.
Nov 07, 2014 | Washing Machines
WATER IS NOT DRAINING IN MY LG TOP LOADING WASHING MACHINE
The first thing I'd check is the water pump if the timer's working ok...
Mar 06, 2014 | Washing Machines
I have a 13 kg Samsung wobble technology top loader and have a problem with washing powder not dissolving. and no! I do not use too much powder per load, in fact am using less and less and my problem
Be aware that most washing powders have filler in them, mostly sodium sulphate. Only the really expensive brands do not. This will not dissolve as readily. Try using liquid wash detergent instead.
It is not a good idea to post your personal email on this public forum.
Feb 10, 2014 | Washing Machines
Ac voltage become hihg or low when start ifb washing machine
Dear, Sir in my IFB Washing...i got a Ac Lo error hiw i fix this Error washing stopped plez give reply sir
Sep 30, 2012 | IFB Washing Machines
My Videocon Fully automatic top load washing machine (Digi Dolphin Dlx 7 kg) gives E9 error and stop functioning
Hi
Aug 02, 2011 | Washing Machines
LG Top Load Washing Machine Model: WF-T7517TE , kg TURBO DELUXE. On Pushing START button , MAchine just starts and stops after a second. Message displays "dE". What to do ?
'de' on LG's stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 20, 2011 | LG Washing Machines
User guide washing machine nikai
I have nikai top loading washing machine6.5 kg, machine showing error code E8 , what is the problem, i have no manual booklet , so please tell the problem to solve.
Jan 28, 2011 | Washing Machines
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
What is sensor magnet in LG 6.5 kg washing machine? Recently I got a dE error and when technicians attended, they said, there was problem to closing door lid. To resolve this, technician replaced sensor...
There really is a sensor magnet that is necessary for door lock mechanism to work. Not sure about service call charge, but if it works the he did fix it anyway
May 19, 2017 | LG WFT1071TP Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
