Question about Olevia Televison & Video
Connecting olevia tv model 237-T12 with blackweb remote
The olevia tv is model 237-T12. The remote that I am trying to connect with the olevia tv is a blackweb remote. And i don't have a code for it and that's what i need
4 Suggested Answers
6ya staff
SOURCE:
leppar
SOURCE: Need code for my Cox Remote Control for my 26-inch Olevia 226 T12
We had this same problem as well and we finally found the answer, the code for the COX remote (silver on top black on bottom) is 1240.
Posted on Aug 29, 2010
Testimonial: "Thank you, Leppar, Thank you for your solution to my problem. Now I don't have to mess with two remote controls to operate the TV. "
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: i need to know how
if you have a universal remote just check if your tv is listed in the manufacture menu.if it does look for the code beside your tv brand.it could have more than one code so you have to try all of them.if you find it then first turn on the tv manually. you press down the code search on the remote it will stay light release the code search button.press and release the tv button on the remote.enter the code found on the remote chart that is pertaining to your tv by entering it on the remote manually. aim the remote on the tv push the the on off button try this with all the codes untill your tv cut off. if your tv does not appear on the remote list use the manual code search.which is.. first turn on your tv manually press and hold the code search button until the indicator light illuminates.trhen you release it.press the tv button on the remote.the indicator light will blink and stays on.aim the remote on the tv and press the on and off button continously until your tv turns off you have to do this up to 200 hundred times continouslly.when your tv switch off press enter to store your code.
good luck/
Posted on Mar 04, 2011
gopakumarg43
  • 76171 Answers
SOURCE: i need the remote code for a olevia tv lcd hdtv
Hello
There is only one universal remote code can be seen for Olivia TV. It is [1027]. Try it. Best of luck.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
CODE SEARCH METHOD
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
ok.
Posted on Oct 15, 2011
How do I connect an Olevia 237-T12 to a cable box
The question is not clear? What kind of 'cable box'?
The good news is yours (apparently) HAS "HDMI" and that's good news if you are asking about a better "Cable TV Box".
IF you write about a INTERNET Cable Box... that's another answer...
Honestly ~ I don't want to waste more time trying to guess!
Sorry
Anthony
Jul 08, 2018 | Olevia Televison & Video
What mode must i b in to program an universal remote to model 237-T12 with just an outside digital antenna connection
Your RCA remote has a code search feature you can use to find a suitable code. If a search through all codes stored in the remote produces no result, you may have to try a different programmable remote.
Jan 05, 2015 | Olevia 237T 37 in. LCD TV
Where can I find stand for Olevia 237-t12
Hello; I would try Jimmy's parts dot com. He has tons of stuff. You can also contact Olevia for the part, but it will probably be more expensive. John
Nov 22, 2010 | Olevia 237T 37 in. LCD TV
I need the 3 digit programing code for my 237-t12
Here is a link that contains most remote codes.
http://www.thompsontv.com/rcarc.html
You should be able to find what you need there.
Feb 18, 2010 | Olevia 237T 37 in. LCD TV
Olevia 237 t12 has hummmmmmmm in the sound
Does the hum go away when you mute or turn down the sound completely? If it does then the issue might be one of the sources connected to it IE: DVD, Cable Box, Satellite receiver..
Nov 17, 2009 | Olevia 237T 37 in. LCD TV
Firmware update Failed
I had the same problem with my olevia 242-T11. I flashed it with the wrong firmware and the TV would not even turn on. The blue LED light would still light up and my PC would still recognize a connection when i hooked it up to the USB cable connected to the TV.
I was fortunate to download the appropriate software. The software is called MTK_DownLoad1.exe. I know this is the correct software to use for Olevia 242-T11 and Olevia 237T. I do not know if this will work with other models.
Here is the link to the MTK_DownLoad1.exe
http://rapidshare.com/files/17475900...load1.zip.html
You will also need to install the USB to Serial driver before you are able to use the MTK Download Utility. The USB Driver is located at
http://rapidshare.com/files/17475900...river.zip.html
BE SURE ONLY TO UPDATE YOUR TV WITH THE CORRECT SOFTWARE OR YOU WILL BRICK IT. I was lucky enough to recover my TV and finally able to upgrade it to the correct firmware but my TV was non functional for about a week and this has been a huge headache and if i could go back in time i would definitely not do it so please ask yourself if its even worth it risking upgrading the firmware of a TV who parent company is reorganizing after declaring bankruptcy.
If you still want to do this, here are the firmwares for all the various Olevia models.
http://olevia.ftpaccess.cc/support/OLEVIA/
I hope this helps all the people who need to recover / unbrick their Olevia TV's. If the links are down or you need any help please ask for help in avsforums. My id is sammykismail on avsforums and i will try my best to help you.
Jun 23, 2008 | Olevia LT42HVi 42 in. LCD Television
Remote control codes
Go to Best Buy and buy the DirectTV Universal Remote Control ($20 and works with all cable and satellite services) Model RC64. It will control all the functions on the Olevia TV and Satellite box, except the A-B-C-D buttons for the User Guide.
The remote codes are:
RCA Satellite Box - 00392
Olevia 237-T12 - 11610
Enjoy
Nick from Ft. Myers
Feb 08, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
26 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
