Plronto M61 1 red Flash 6 green flashes what does it mean
6ya staff
SOURCE:
Anonymous
  • 78 Answers
SOURCE: What does a flash green
the green key means that the immobilizer that is built into the ignition switch is not reading the key properly try switching keys as far as the car not turning over this green light has nothing to do with it but if the car is turning over and not starting it means that the immob. is not reading the key again try switching keys if this doesnt work then the key or keys have to be reprogramed at a honda dealer if you have to do this make sure you take all of the keys to that car
Posted on Nov 29, 2008
TONY BIGNELL
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
Anonymous
  • 7 Answers
SOURCE: energizer AA charger
bad battery
Posted on Jun 08, 2009
Anonymous
  • 3 Answers
SOURCE: I have a sony KF-42WE610. When I go to power it
More than likely it is the G1 board or Thermal Fuse. I replace the thermal fuse and it is still giving me the 6 blinking red lights. Thermal fuse is $40 and cheapest G1 board I have found on-line is $120. I am about to pull the trigger on the G1 board and give it a shot.
Posted on Mar 04, 2010
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: The LED's on my Energizer charger flash red and green constantly.
If your charging 2 batteries only they must be palced in the following poistions on the charger
1. both side by side in the 2 left slots
or
2. one each in the two right slots.
Otherwise the batteries will not charge.
The users manual can be downloaded here:
http://www.energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
Thanks for using FixYa.
Kelly
If the batteries are charging the battery indicators
Posted on Mar 24, 2010
Testimonial: "You sussed it. Thankyou very much."
Hp 8000 Solid Red light
desktop small form factor, SFF, (not silly fat frog)
no statement as to where lamp is, I'll guess, FRONT.
just the light bothers you, only..?
why not RTM read the manual to learn what it means.?
so where is said LED lamp, ? front of case on the SSF case?
HP calls it, and searches only work with this.
HP Compaq 8000 Elite Small Form Factor PC./
im reading your manual now for you at HP.com
my guess is lamp 5, (pwr) is not green now but is red
green means power ok, red means, not ok.,
page 2:
if flashing , the flashes are codes, what is your flash code if flashing
if not this LED then say which one?
green on 5 means ok. power ok, no errors. red bad.
sff-s5z5x1uvxsiidstn2afwkml2-3-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01957825
the flash codes are here. page 47 ,
http://h10032.www1.hp.com/ctg/Manual/c01960471
you stumped me, the service manual shows no steady red.
why not ask at Hp.com
more manuals here
https://support.hp.com/us-en/product/hp-compaq-8000-elite-small-form-factor-pc/4065894/manuals
hp forum here.
http://h30434.www3.hp.com/
May 05, 2017 | HP Computers & Internet
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
My kdf-e42a10 tv won't come on flashes green 7 times then flashes red 3 times.
The 3 blinks is lamp door not closed, what it really means is the door may be warped from the heat of the lamp===the door has a plastic peg on the back that when the door is in place engages a lever just behind the door. If the door is even a little bowed=three blinks.
Engage the lever with something not metal and see if set comes on, if it does replace the door.
Apr 08, 2012 | Sony KDF-E42A10 42 in. LCD Television
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
SONY 62 LCD GRAND VEGA HD TV
A three flash means you have not seated the lamp cover correctly. Try recolsing and relatching the lamp cover
Dec 21, 2008 | Sony KDF-42WE655 Television
Can you help me with kyocera fs-1030d
If a paper jam occurs while printing, the printer notifies it by the following combination of the four indicators. Remove the
jammed paper . After removal, open and close the top cover once to initialize the jam sensing
Dec 04, 2008 | Kyocera Mita FS-1030D Laser Printer
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Will not flash red/green
This means Battery is low to charge the capacitor.
I suggest you test this with unused new Duracell.
Oct 06, 2008 | Vivitar 285HV Flash
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
