How to remove the base from a 42 auria tv - Televison & Video
5 Suggested Answers
6ya staff
SOURCE:
MICHAEL MULLINS
  • 927 Answers
SOURCE: I need to remove the
Good Day;
The base is attached by four, inset, allen screws on the back of the unit, bottom. The 'key' word is INSET (recessed).
Good Luck, Day, Big Irish.
Posted on Jun 18, 2008
larrydan
SOURCE: removing the base on a tv
There are 5 screws on the back of the TV under the inputs in an x pattern:
X X
X
X X
Remove these and set aside. You should also see 2 screws on either side of the X pattern, loosen these. You should then be able to slide the TV off the base. Remember to re-tighten the loosened screws. Place the removed screws in the base in case you ever wish to use it in the future.
Posted on Dec 02, 2008
Doldog
  • 222 Answers
SOURCE: Looking for base stand for 42' plasma tv
try Ebay
Posted on Jun 12, 2010
mnwarfield10
mark warfield
  • 452 Answers
SOURCE: HOW DO YOU REMOVE THE BASE ON A 42" FLAT SCREEN
you will have about 4 -7 screws on rear of tv ... normally there a bit bigger than rest ...
Posted on Feb 27, 2011
I need a remote control that will have for auria
0071 0101 0113 0152 0181 0236. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 24, 2014 | Televison & Video
I DON'T KNOW THE SERVICE MENU OF auria lcd tv i want to reipear it
check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 13, 2014 | EQD Auria EQ3288 32 in. LCD TV
I need to buy a new or used base for my 42 in proscan lcd tv.
Other than going to Thompson who is RCA/GE/Proscan you can Google the model number with base to see what is available.
Dec 10, 2012 | Proscan 42LA45H 42 in. LCD TV
Auria eq5588, cannot find code for DTV.
Auria is not even in the menu here so I had to select DirecTV DVR DTV. Someone needs to keep up with the brands. Anyway, the DTV codes for the Auria EQ5588 are: 11423, 10017,11265, 10178, 10856,11178 These are the codes. Mine worked with the first one.
Feb 16, 2011 | Directv Plus DVR DTV Receiver / 100-Hours...
Auria eq2288f 22" lcd tv
What has happened is that one or more of the back light tubes were broken in shipping, AURIA used hard foam packing and the TV could not handle the shock of shipping because of BAD PACKING from AURIA. if you call customer support they will tell you that is a power supply or inverter issue but it's not it's a broken bulb, you know they know about it because they will not tell you one or the other. if you open the Samsung screen (LTA400HM01) you will see that the bottom back light bulb is broken, why AURIA will not address this issue is beyond me. don't waste you time or money on power supply or inverter boards before you look at the back light bulbs.
Jan 19, 2011 | Televison & Video
How do i remove the base of my 42" lcd
Lay TV on its face. Remove the plastic base cover by squeezing to release the tabs. Remove the bolts holding the base.
If this is helpful please rate.
Oct 02, 2009 | Vizio GV42L 42 in. LCD Television
Akai PDP42Z5TA 42 in. Plasma base removal
If you ever get the base off, I'd like to buy one.
Apr 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
How to Remove the Base
I have an Olevia 42" TV. I was able to remove the base by removing 16 screws on the back side. They were arranged vertically in 4 sets of 4. The screws go through the back panel, through the base and attach (without nuts) directly into the inside of the TV. After removing the 16 screws the stand simply slides out.
I tried removing two screws underneath the base area. They were small screws and were a pain to remove. I thought I would try that first instead of removing 16 screws but that did nothing.
Dec 10, 2007 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
