Question about Toshiba Office Equipment & Supplies
Toshiba duplo dp g-200 error code E012 can someone please advise thank you
When making master error code E012 pops up
6ya staff
SOURCE:
Anonymous
  • 11 Answers
SOURCE: paper jam and error code e012 on ir6000
You could very well have a worn registration clutch, it's behind the the gray roller that sits to the right under the drum. Good luck! If that doesn't do the trick you may have to change your transfer settings in service mode
Posted on Oct 29, 2008
color_50
color_50
  • 22 Answers
SOURCE: error e012-0001 problem
It is a Drum Drive system over load/ or Drum Motor issue/ DC pcb issue. Need to check drum blades for all colors or if Dev. units are locked up.
Posted on May 07, 2009
Everett Lin
  • 990 Answers
SOURCE: i have canon 6085 very bad print and code error
Hello sir; Looks like the drum motor have problem, open back cover find out drum motor and look around have any gear broke if everything fine then replace motor that is necessary.
Posted on Jun 13, 2009
Anonymous
  • 5 Answers
SOURCE: Got error code e104 duplo DP-460H
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Posted on Sep 02, 2009
Anonymous
SOURCE: ERROR CODE E001 DUPLO DP-C120
DUPLO-C120
Posted on Jun 24, 2010
Please help me, I have a Duplo machine DP 1000s and it's giving me service call E1-1. What would be the problem?
The problem would be that you have to telephone a Duplo service representative and report error E1-1.
Jul 16, 2018 | The Office Equipment & Supplies
Please help me, I have a Duplo machine DP L500 and it's giving me service call E001. What would be the problem?
    ewol3i Apr 01, 2012
    main motor error..check main motor boards fuse at the back of the machine or the timing belt might be damage
  • Joseph Nov 28, 2013
    check the encoder sensor
ERROR CODE E001 DUPLO DP C120 Duplo Office Equipment Supplies
The manual is here, although it does not mention error codes.
http://www.toshiba-sa.net/Documentation%20%20Duplo/DPL-500/DPL-500_Instruction_Manual.pdf
Duplo machine DP L500 error E001 Google Search
Mar 07, 2018 | The Office Equipment & Supplies
Please explain me the error code of Duplo DP A100 printer the error code is: E012 cordially thank you
You may need a maintenance kit . Check right side interlock It my be broken.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Nov 23, 2014 | Office Equipment & Supplies
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
Hi, how do i find out what the usage of my dp21s is (total copies & masters. alec
No error on the display but when i press on plate making sometimes nothing happens.DP-21s
Aug 27, 2009 | Duplo Office Equipment & Supplies
Jan 08, 2009 | Duplo DP460H Copier
23 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
