Question about Sanyo Televison & Video
I have a sanyo tv the picture keeps going black but I have sound still
6ya staff
SOURCE:
nomn
  • 10 Answers
SOURCE: Sanyo DS24425 24" TV has great sound and no picture(black screen)
if TV have black screen,increase screen control to see vert amp IC is defective if you see one horizontal line in picture tube screen,and if screen is white with lots of line acrose ,you can find open resister,on picture tube board,or in main board near HV transformer.
Posted on Jan 26, 2008
Anonymous
  • 129 Answers
SOURCE: tv has sound but picture is black
good day.
The crt circuit of the unit might be loose or the the parts inside the board is loose. Have it hecked by a technician first. Minor parts inside might caused the problem.
Response is highly appreciated.
chris
Posted on Mar 29, 2008
Anonymous
  • 150 Answers
SOURCE: sanyo vizon tv black screen
hiiiiiii here shivam
i want to tell you that that same problem is occuring my computer but now it is fixed
but your problem is of tv don't worry is this is help full to you--
this problem is common on this model. your vertical output circuit has gone bad. but i am sorry to say that a repair cost is to much for a tv this age. a cost would range 100-150. i say invest this into a newer tv. this model was good for 10-12 years and you have got better than that.
good luck :)
let me know if you need more info?
Posted on May 24, 2008
Anonymous
  • 19 Answers
SOURCE: LG 42LG5 TURN ON TV PICTURE GOES BLACK
This could be 1 of a few things here. Without opening up your set and trying to look at voltages or indiciator lights I couldn't tell you exactly without some more info.
Without looking at it myself here are my thoughts and where I would first look at.
It may be a main board because:
1) Main board processes all your audio/video signals. Bad main board means bad video processing. Could do that. Especially if the main board is not sending the right signal or a bad signal to the rest of the boards so they don't do their jobs.
It may be a power supply because:
1) Power supply is well, the power supply. If it's sending inadaquete voltage to the main board you may not be recieving enough juice to keep that main board doing your video processing or further up the line keeping enough juice flowing to your TCon board to keep it telling things where to go and what to do. The power supply sends voltages to your Ballast board(controls your lights) and to your main board through which power is supplied to your TCon board via a LVDS line and a +12/+16V signals. If the power supply isn't pumping out enough juice to keep the TCon or Main Board running, it could be a problem. By the same token it could be that your P/S isn't sending power out to your ballast board.
It could be a TCon because:
1) If the TCon is bad, you won't get your pictures. This could be the TCon board itself or the LVDS cable from your TCon to your Main. However, with few exceptions, if it's a bad TCon you're looking at a total panel replacement.
It could be a ballast board because:
1) The Ballast Board controls the lighting behind the LCD screen. If this isn't working right you won't be seeing much of anything without that back lighting. If this is bad, it's a panel replacement. These are not field replaceable items by LG.
Based on the symptoms, without more data or a eyes-on view of it, I would say you're most likely looking at a Main Brd or PSU problem.
Posted on Feb 21, 2009
Anonymous
SOURCE: my sanyo tv has no picture no sound 31"color tv
my grand son unplugged my sanyo tv 32in from wall while on no wi have no picture and no sound
Posted on Aug 05, 2009
Sanyo DP26649 screen blacks out and sound becomes loud static
Most likely you will need to get a diagnoses performed on the set. Your problem could be with either the main board or power supply board. The million dollar question is do you repair or replace? With parts and labor to repair this set, you could come out cheaper replacing it.
Jan 15, 2013 | Sanyo DP26649 26 in. TV
My Sanyo 42" flat screen
There is a problem with the board of your television.That problem is in vertical section, theres a leak capacitor at the vertical section of the board.Its better to replace all the leak capacitor to make the picture back to normal appearance.If you can't do the repair or replacement of of capacitor try,Call a repair technician to do the repair or troubleshooting..Thanks..
Aug 25, 2011 | Sanyo 42 in. LCD TV
Sirs: I have a new Sanyo 42" TV. We are on
Hello
If picture and sound is ok, and there is no colour, your push have sometimes made its system changed. I don't know from where you are, and to which country you belongs. Anyway I'll give you one solution.
Your Sanyo Tv may have multisystem compactable. There are mainly three systems in transmision of TV signals, called PAL [Phase Alternating Line], SECAM [Sequential colour and mamory] and NTSC [National Telivision System Committee]. Most of the europian countries have transmitters with SECAM and NTSC. I belongs to India, and here we have PAL BG system.
If the system has changed in the tv, the picture will not have chroma information, ie ,colour information, and black and white picture will be the result. You just do one thing. Just get into the Menu of your TV, according to its documantaion that you have, and go to the system menu, and make it "AUTO". This will solve your problem. Ok.
Nov 24, 2010 | Sanyo DS31520 31" TV
Sanyo dp42647 picture is black but has good sound worked great yesturday
sanyo lcd dp42647 turns on and has sound no picture black screen
Dec 27, 2009 | Sanyo 42 in. LCD TV
My sanyo tv has no picture no sound 31"color tv
May 17, 2009 | Sanyo DS31520 31" TV
Sanyo clt1554 has sound no picture.
I have a Sanyo CLT1554 (2 1/2 years old). Has perfect sound but no picture. The picture will come after several times turning it off/on and pressing the Reset button. It is very anoing to do this evey time. PLEASE HELP
Dec 15, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
No sound and black screen
lets get together, start a list of names and sue companies selling crappy wares at way too high prices! email saryejade@aol.com
Nov 09, 2008 | Sanyo DP42746 42 in. Plasma Television
May 20, 2007 | Sanyo DS24425 24" TV
Televison & Video Logo
21 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
