How do I rescan my antenna TV? - Televison & Video
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 58 Answers
SOURCE: I have an rca flat antenna. June 12 I rescanned
you probably need a digital converter box
Posted on Jun 15, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Posted on Dec 17, 2012
Did the channel scan for OTA stations, is there a way to hold these stations so I can turn antenna and rescan for more stations?
Guide to help get more channels on digital tv
spartacus-searching.com/dtv.html
Orginally there were many tv stations but the government decided to force ... Alsothese televison signals are more difficult to capture than before with analog signals. ...So that's not accurate when we are trying to find a TV transmitter. ... web page will tell you rescan for channels, thats great if you raise your antenna or have ...
How to sharpen digital TV reception via antenna
Jan 18, 2016 | Element Electronics Televison & Video
Set up indoor antenna
Plug antenna cable directly into antenna input on tv. Place antenna where you believe you will get a signal (don't know where you live but you can look up site map for optimum direction). Go into tv menu set tv to air and auto scan air channels. Your set will receive and memorize available channels. In your sets menu you should have a strength meter. You can use this to tune in the strongest possible signal. You may have to go back and rescan the channels because if you improve the antennas position you might pick up more channels and they won't just come in automatically. Once you've scanned and received maximum number of channels there will be no need to rescan again. If you do you run the risk of losing some channels and only a rescan under optimum conditions with regards to antenna position and environmental conditions will gain those back. Keep in mind some fringe channels may come and go. Hope this helps.
Feb 01, 2015 | Televison & Video
These answers do not fit my question. One day, on three different sets in my home, where I have received NBC for years just quit working. Did NBC quit broadcasting? It is not snowy, etc, it is just no
Ok This is what I found out and hopefully found your solution..
Have you heard of Double Rescan?
The Federal Communication Comission Designed a Process called double rescan.
Double Rescanning erases and thenreprograms the channels in the converter box an digital TVs memory.
To Double Rescan, you will first need to disconnect the antenna from the converter box or antenna.
Then disconnect the converter and or digital tv power supplies from the wall. Wait a minute before plugging them back in. The antenna should still be disconnected.
With the antenna disconnected run the channel scan function on the coverter box or digital tv. When the scan completes you will have completely removed any channel data the converter box or digital tv, had in its memory.
Now it's time to rescan for real.
Do this by reconnecting the antenna to the converter box or digital tv and running the channel scan function again.
Thus the double rescan is born.
If the double rescan doesn't work, then try some tips and tricks to get your converter box up and running..I will have to look up the url again that has the tips and tricks...
If the double rescan doesn't work let me know and I will look up more options..
I really hope this works..
Dec 18, 2014 | Samsung Televison & Video
I have an LG47LG70 tv which has recently started flashing the screen on and off when hooked up to the local antenna. It works fine when hooked up to the Dish Network cable. I have replaced the antenna...
Tries hook up to a roof antenna or a better antenna like a digital antenna.Than rescan ur tv again,for those DTV free air channels again.Ur tv now,should get all those DTV free air channels.
Nov 05, 2010 | LG 47LG70 42 in. LCD TV
Some of my channels were lost after I TRIED RESCANNING I I LOST
Check your antenna direction (antennaweb.org or tvfool.com are good sources for signal direction). When I lose channels, it's a digital signal that came in with "bad signal" strength and my external antenna has rotated in the wind. (Oddly another TV in the house doesn't seem to lose the signal as easily even though they share an antenna.)
Also check the weather conditions and time of day. I've gained distant channels when scanning near sunrise or sunset and lost others during thunderstorms.
I hope this helps.
Jun 07, 2010 | Vizio L32 32 in. LCD HDTV
The words "weak signal" flashes on screen at different places and do not receive a picture.
seems like you are using an "off the air antenna" that receives weak signal, you may be too far from the station, go get a roof top amplifier antenna or subscribe to digital service from cable, satellite or at&t uverse. If you think your antenna is getting good signal, try to rescan your tv for available channel. Make sure your TV set up is correct, if you are using Off the air signal, your setting should be set at "Antenna or off the air", then rescan your TV. Normally on Satellite or cable box, you just watch it on video channel or component input, if you are using HDMI then tune to HDMI channel.
Check your connection to make sure they are making good contact. If you can post your set up, I can better solve your problem.
For a resource on "off the air" antenna, go to www.antennaweb.org for help.
Aug 16, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Jun 15, 2009 | Televison & Video
WHY MUST I RESCAN ALL THE TIME?
You may have several problems. If you are using a indoor antenna, upgrade to a outdoor antenna. The indoor antenna has to be adjusted every time you change a channel. If you plan to sit in a chair and never move when watching tv, you may be able to pick up a channel or two. Get a UHF/VHF antenna from a home improvement store. The big box electronic stores are selling a digital antenna. There is no such thing. The antenna doesn't know if the signal is digital or analog, it just picks up uhf and vhf signals. The other problem could be that the box is bad if it is not saving the scan. I would check the antenna first from what you said though.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
