TV turns on and off by itself - picture and sound comes up then back off keeps repeating
Https://www.youtube.com/watch?v=AuWhoi5--2o
It's usually because your remote batteries are low. Remotes are known to send off some weird signals when they're on the last bit of juice. Your TV could be interpreting infrared noise from your remote as an "On" command. The power button on the remote or the TV itself could be stuck.
https://www.quora.com/Why-would-a-TV-turn-off-and-on-by-itself
Samsung
Try to update the software.In some cases, a software update can correct the problem. ... If the TV turns off during the software update, it could damage the TV. Updates can take up to 30 minutes depending on network speed, so if the TV is not turning off too frequently, try updating the software.
https://www.samsung.com/us/support/troubleshooting/TSG01108742/
LG:
A TV that intermittently powers on or off is usually caused by the timer setting. ... Check if the TV power cord is securely plugged into the wall outlet or the power bar. 3. Time menu options affect TVs turning on or off automatically.
https://www.lg.com/ca_en/support/product-help/CT20098005-1412238468277-intermittent-power-or-powers-off-on
SONY:
Your Sony BRAVIA KDL-46XBR9 TV may reboot due to a damaged AC power cord. In this case you can usually resolve the rebooting problem by replacing the power cord. Your Sony BRAVIA TV may also reboot because of a bad power supply in the TV. ... The BRAVIA KDL-46XBR9 may also reboot because of incorrect settings on the TV.
https://www.techwalla.com/articles/why-is-my-sony-bravia-kdl-46xbr9-rebooting
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
SOURCE: Sharp lc-32sh12u...no picture
It can be either the LCD panel driver board, or the worst case is bad LCD panel.
Testimonial: "Thanks for the response. I found a PWB board, a Power board and an AV board. Would one of these fix the problem?"
SOURCE: my sharp lc 32d42u shut off and won't turn back on
IF YOU STILL HAVE SOUND I AM PRETTY SURE WHAT THE PROBLEM IS...
SOURCE: MY POWER KEEP GOING OF SHARP lc-20b2ua
I have the same problem. I fixed it for about 3 months by wrapping duct tape around the large pack midway in the cord (where the wall plug and TV line plug in). But, it started up again this week. I can't get the "box" open either, but that is where the problem is. Mine is mounted to the wall, so no one ever touches the cord. I'll let you know what we find when we get it opened.
SOURCE: Sharp LC -46SB54U will not
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Do take care.....
I am having the exact same problem. Not happy this TV isn't even 3 years old. Never buying a sharp again.
