Question about Dual Cell Phones
I need to remove the cistern lid of my Porcher dual flush as it is not flushing
The problem is that the two flush buttons appear to be fixed together, they do not press/flush independently. This means the normal method of pushing one in and lifting the other out does not work. Any ideas?
6ya staff
SOURCE:
jpintore
  • 129 Answers
SOURCE: i needs new valves for my dual flush, close
No I'm sorry they do not. You might try plumbing supply house in your area.
Posted on Sep 26, 2009
jharvey572
Chris Harvey
  • 447 Answers
SOURCE: Buttons on our concealed dual
the ring where the buttons are should unscrew and the full unit should pull out,if that dos,nt stop the water try to gently pull the plunger up, if that stops it push the plunger back in to flush toilet,see if plunger returns to normal position and water stops, if that dos,nt work have it checked out by aservce engineer.
Posted on Jul 09, 2011
John Meijer
  • 129 Answers
SOURCE: toilet keeps on running with
ok:) i was with you until you said the cistern (tank lid) was sealed down. what do you mean and can you see anyway to remove the lid because we have to in order to fix the problem:)
Posted on Jul 27, 2011
ugali
  • 3 Answers
SOURCE: I have a Vitra dual
Have you tried to remove the outer ring by unscrewing it before you attempt to remove the buttons? I don,t think you should remove the buttons first.
Posted on Sep 01, 2011
ASB_SOCMEDIA
  • 4 Answers
SOURCE: My porcher toilet wont flush....
Hello:
Please feel free to call Customer Service 1-800-359-3261
General Customer Service
Monday through Friday
8:00 A.M. to 7:30 P.M. EST
Technical Customer Service
8:00 A.M. to 6:00 P.M. EST
8:00 A.M. to 3:00 P.M. EST
Customer Care at Porcher Porcher Customer Care
P.O. Box 6820
1 Centennial Plaza
Piscataway, NJ 08855-6820
All the Best,
Paul, -ASB
Posted on Sep 12, 2011
Fixing toilet flushing
A lot depends on siphon in cistern and cistern.
The old cisterns were 9 ltrs and rule and regs brought that down to 7 - 7.5. Most siphons have a dual flush, press and left go for short flush and press and hold for long. Long flush for heavy waste and short for just liquid.
Jul 01, 2018 | Home
Flush button, when pressed nothing happens
Grasp the collar that surrounds the button and turn counterclockwise to unscrew it and allow the cover to be removed.
Hope this helps.
Bob
Jun 22, 2014 | Porcher Home
Leaking toilet from overflow
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing
If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
Feb 20, 2018 | Porcher Home
Cant get the lid off a push button cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to left out the second button, then release the first button and pry that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Feb 01, 2011 | Duravit 0910100005 Happy D Toilet Cistern ...
How do i take the lid of the cistern
There is a trick to this for Porcher toilets. Push big flush button down, then lift up and out the small button. The big button lifts out. Undo plastic bolt and lift up lid. cheers, zoofish
Dec 18, 2010 | Porcher Toilet Seat Veneto 70032.001
How do I get the lid off a stylus toilet cistem
Solution I received " lever up the two flushing buttons with a fine blade screwdriver.
They may be a push fit on two plastic posts. Once off, they reveal a screw between them. Release this to remove the cistern lid. Make a note of the position of the buttons as they only fit one way round."
Feb 07, 2010 | Caroma 270W-RF Reflection Round Front...
Does not flush completely. Works 2 out 3 times.
Needs new flushing mechanism. Remove Cistern, Remove flush siphon and either replace siphon washer or replace complete siphon.
Jun 09, 2009 | Porcher 40050 Classic Elongated Toilet...
Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Cell Phones Logo
35 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Ekse
Tin Tin
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
