It's the circle that the windshield suction cup fits into
Garmin Nuvi 52lm GPS
Amazon
https://www.amazon.com/slp/garmin-nuvi-replacement-bracket-cradle/g2se2a2psm2n7n6
SOURCE: problems with the window mount that comes with the Garmin 360
You just have to push the ball part on the window mount into the socket part that holds the GPS. It's pretty tight, so you have to press pretty hard.
SOURCE: Garmin Suction Cup (Rubber)
Put a drop of dishwashing detergent and a few drops of water on the rubber and distribute it evenly before You mount it to the windshield. This mixture enhances the suction power and keeps the rubber soft. Repeat after 3-4 months! If You don't like the look of it on the outside of the window, put a smiley sticker on it! :-)
SOURCE: I got the standard mount with TomTom GO 730 and it
This is a fairly common issue especially with aftermarket tinted car windscreen 'film'.
You can try prolong the suction by wetting the suction cup with water of very slightly soapy water before applying it to your 'clean' windscreen area.
As for the dashboard, for some models, TomTom provide a plastic circle to which the suction cup attach to. The plastic circle is first 'permanently' attached to your dashboard with double-sided adhesive tapes.
Hope it helps: let me know how you go.
SOURCE: Suction cup does not stick to the base.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
