Need new stabilizer clip/bolts for ASKO washer model W6461
I have an ASKO washer model W6461 and I need to buy 2 new stabilizer clip/bolts that have the rubber around. The washer works but spins all over wildly and loudly too.
buy a new machine,the spider gear is broken and it's around 500 bucks for the part,you can buy a new washer for that,you used to much detergent,it eats at the metal on the spider gear and it falls apart,i've found parts of it inside the pump before.
you may find the leak coming from the door seal or the soap drawer while it is filling,if you leen the machine back you will find two T20 screws under the front.you can get the book from asko.com.au
I am a technician for Asko in Australia.The blackness on the motor control unit(circuit board) is probably carbon dust from the carbon brushes in electric motor.Likely problem is motor brushes have totally worn the armiture in motor or the MCU needs replacing due to earth leakage or short.Purchasing the parts from Asko should be no problem, but if you purchase and install electrical componenents only to find problem unresolved, you can't return installed parts for a refund. Also the breather hose from the detergent dispensor to outer tank can leak from tank connection when spinning load , and result in water running down outer tank and onto the electric motor causing circuit breaker to trip.....possibly damaging motor too. Goodluck!!
