Question about Bosch Washing Machines
Bosch wall oven HBL3450 UC/09 stopped working and began flashing error codes E009 and E005. I replaced user interface and control module and checked all electrical connections-didn't help.
6ya staff
SOURCE:
Anonymous
  • 146 Answers
SOURCE: F2 code and consistent beeping with my Maytag Electric Wall Oven model CWE5800 or CWE4800
The F2 code indicates a stuck relay. You will have to replace the relay board. It may be a stand alone board or it may be part of the ERC Electronic Range Control. If you know how to check you won't have to call a tech.
Posted on Dec 21, 2007
opstud
SOURCE: Electrolux Wall oven E30EW75ESS
Same F23. Resetting the beaker seems to fixed it. Thanks to all
Posted on Jun 07, 2008
vitg55
Vitaliy Gins
  • 78 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Dec 18, 2008
Anonymous
SOURCE: 326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem. We had to contact GE and have someone replace the panel. It was a few hundred dollars.
Jim
Posted on Nov 02, 2009
NJ Quail Run
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Posted on Jul 06, 2011
F21 fault code on Electrolux dishwasher. What does it mean and how can i clear it??
Electrolux Dishwasher Error Code 01
Fault Condition: Water Leak Is Detected (Sensor under the dishwasher detected a leak)
Repair or Check: Remove power to the dishwasher. Check hoses, pumps, and tub to find the leak. Replace any parts leaking.
Parts Required: Drain Hose - Drain Pump - Recirculation Pump
Electrolux Dishwasher Error Code 02
Fault Condition: Thermistor Sensor Fail
Repair or Check: Remove power power to the dishwasher and check the thermistor sensor circuit wiring. If the wiring checks out then replace the thermistor sensor.
Parts Required: Thermistor Sensor
Electrolux Dishwasher Error Code 03
Fault Condition: Wash Motor Fail
Repair or Check: Remove power to the dishwasher. Inspect the wiring for the wash motor. If the wiring checks out then check for an blockage in the pump. Replace the wash motor if the pump is not blocked and the wiring checks out.
Parts Required: Wash Motor
Electrolux Dishwasher Error Code 04
Fault Condition: Upper Fan Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the upper fan. If the wiring checks out then replace the upper fan.
Parts Required: Upper Fan
Electrolux Dishwasher Error Code 05
Fault Condition: Upper Fan/Vent Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the upper fan vent. If the wiring checks out then replace the upper fan vent.
Parts Required: Upper Fan/Vent
Electrolux Dishwasher Error Code 06
Fault Condition: Lower Fan Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the lower fan. If the wiring checks out then replace the lower fan.
Parts Required: Lower Fan
Electrolux Dishwasher Error Code 07
Fault Condition: Drain Valve Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the drain valve. If the wiring checks out then replace the drain valve.
Parts Required: Drain Valve
Electrolux Dishwasher Error Code 08
Fault Condition: User Interface Control Fail
Repair or Check: A switch on the user interface is possibly defective. Replace the complete user interface.
Parts Required: User Interface Control
Electrolux Dishwasher Error Code 09
Fault Condition: Communication Fail From User Interface Control TO Electronic Control Board
Repair or Check: Remove power to the dishwasher and check for any loose wiring connections between the user interface control and the electronic control board. If the wires and connections check out then replace the user interface control. If the problem persists then replace the electronic control board.
Parts Required: User Interface Control - Electronic Control Board
Electrolux Dishwasher Error Code 10
Fault Condition: Electronic Control Board (Relay) Fail
Repair or Check: A relay on the electronic control board possibly failed. Replace the complete electronic control board.
Parts Required: Electronic Control Board
Electrolux Dishwasher Error Code 11
Electrolux Dishwasher Error Code 12
Fault Condition: Drain Valve Position (Drain valve has activated when it should be turned off)
Repair or Check: Remove power to the dishwasher. Check the drain valve wiring for an issue. If the wiring checks out then replace the electronic control board. (This is because the drain valve relay on the control board is stuck) If the problem persists then replace the drain valve.
Parts Required: Electronic Control Board - Drain Valve
Electrolux Dishwasher Error Code 13
Fault Condition: Electronic Control Board Fail
Repair or Check: The control board has a component failure. Replace the complete electronic control board.
Electrolux Dishwasher Error Code 30
Inconsistency between level on electronic pressure switch and level on anti boiling pressure switch.
Electrolux Dishwasher Error Code 50
Fault on the wash motor circuit. On some Electrolux dishwashers the motor has a control board located at the back at the bottom just behind the wash motor.
Jun 18, 2018 | Electrolux Dishwashers
Tip
Whirlpool duet F70 and F71 error codes.
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
F71: USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
To get parts and diagrams try entering the full model number in one of the websites below:
Enter the model number ..
To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
on Nov 05, 2010 | Whirlpool WFW8300SW
We have code F84 coming up on our Electrolux microwave, wall oven. Seems to be affecting the microwave. Any ideas what might be going on?
The F84 code is a communication error between the user interface panel of the microwave and the main control board. This could be the result of a problem with the touch panel's interface board, the main control board or the wiring between them. (The wiring harness can come loose or have a bit of corrosion at the connectors.) The usual recommendation is to check the wiring at the interface board then replace the interface board first. If that doesn't solve the problem, you have to replace the control panel.
If you add a comment with the model number of the unit, I may be able to help you find the parts your unit needs.
I hope this helps.
Apr 09, 2017 | Electrolux Microwave Ovens
I have a front loader MHWE3000VW12 it's giving me a code F70 Ineed to know what it means
Thanks
Jul 26, 2012 | Maytag Washing Machines
Whirlpool duet getting error code F70 and F71. When hitting start button, getting a clicking sound and nothing is happening. Cannot open the washer door as it is locked with clothing inside it.
Hi jreib29,
Hope this helps.
Thank you for using FixYa.
Sep 17, 2011 | Whirlpool Kitchen Ranges
What is err 70?
Repair is difficult, as motor, wiring and voltages from control modules must be tested. Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
Hope this helps.
Aug 04, 2011 | Kenmore HE2 Plus Front Load Washer
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic
mode and verify the error codes. Ensure AM software, UI software and EEPROM
CHECKSUM versions appear on the lower text line. If AM software and EEPROM
versions do not appear, UI and AM may not be communicating. Verify this for the
lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show
the AM software version for the lower oven appliance manager, and the microwave
UI will show the AM software and EEPROM versions for the microwave appliance
manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT
DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions,
go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND
EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER
OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
Washer will not turn on flasheing F71
F71 error code USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit. Possible Causes/Procedure 1. Check for continuity of the User Interface harness. 2. Check wire harness connections to the User Interface and the Central Control Unit. 3. Replace User Interface if drum is rotating. 4. Replace Central Control Unit if drum is not moving.
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
We just plugged in our oven and it has E005 Communication error popping on the screen. Any ideas?
1. Turn the clock selector knob to OFF
2. Tweak the oven control by turning the clock selector knob slightly to the left (counter clockwise).
This may stop the popping message.
Thanks
May 31, 2010 | Bosch HBN5650UC Electric Double Oven
Panel is showing f7 and flashing e6 57 56 58 5a
F7 is a stuck key. Usually you can't get a key unstuck. Best thing to do is replace the keypad / user interface. Here are some of GE's error codes:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Dec 01, 2008 | GE Profile 30" Self-Cleaning Slide-In...
Washing Machines Logo
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
