Hi, I believe there might be something wrong with the program/software on the Yamaha PSR-2100 keyboard. When turned on I get the following:
Assertion failed!
Condition:0
File:.¥src¥hisysdwn.c
Line: 133
Address Error (read)!!
Param: H'8c1773F0
From there on, I cannot use the keyboard. Has anyone else experienced this? Does anyone know of any solution?
I would be grateful if someone would have a solution, I have checked elsewhere and haven't seen a solution yet. Thanks.
I would do a factory reset. Search Google for: factory reset PSR 2100.
It will be holding certain buttons or keys down when powering on.
Hallo!
This Assertion failed... error is a beginning of a deep hardware problem. Only with motherboard replace or chip change will help. No more switch on/off to prevent the largest burn.
If you have a bad psr2000 or psr2100, please contact me. I will service or buy your faulty instrument. Mail : szelepi "at" isis-com "dot" hu
I had the same problem.
A factory reset did not work, i deleted all Files an user Data. Got still the same message (bluescreen).
Finaly i took the help of a Yamaha specialist:
Small peace of hardware did not work any more. He had to solder something. => 200€ an my psr works fine :-)
