Question about Watches
I have a skegan watch changed battery still didn't work had it about 4 years asking is it worth trying toget it fixed I've seen a few negative comments
6ya staff
SOURCE:
Anonymous
SOURCE: Longines watch problem
Some longines watch has built-in battery gauge. When battery is low, the second hand jumps every four seconds. If you have new battery installed and the problem persists then there is a short circuit somewhere that drinks a lot of battery juice.
Posted on Mar 28, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: my watch just stopped working, i take get care of
It definitely is worth to fix. But I suspect that all you need is just a battery replacement. Don't forget, that before you purchased your watch, it was laying on dealers shelf for no one knows how long. Battery originally is fitted at Tag Heuer's workshop in Switzerland, and nobody was replacing battery when you bought the watch, so, it may have been in the watch for a year or even more before watch was sold to you.
Rate me, plz.
Posted on Jan 12, 2010
Conrad Jacoby
  • 172 Answers
SOURCE: I bought this watch 1.5 years back.I have started
On average, I've found that analog wristwatches that use a silver oxide (or alkaline) battery last about a year after a fresh battery has been installed. Digital watches, because they have no moving parts, will typically last longer on a set of batteries if you're not using the alarm or backlight function. Watches that use lithium batteries generally last two years or more between battery changes.
Based on your model watch, I would guess that your battery has run down too far to power the movement. A fresh battery will probably fix your watch. Hint: in the future, if you aren't going to wear your watch for a while, pull the stem out into the "set" position. That will stop the movement and extend the life of your battery. When you want to wear the watch, simply set the time (and date, if you have a date window) and push the stem back in.
Posted on Jun 29, 2011
Howard Scott
SOURCE: I've not worn my watch in 7 years. I did not think it had a battery. It charged from movement. I tried to wear 2 days and still it does not work.
It probably needs a good cleaning and lubrication. This can be done at any watch repair shop, even the ones they have in Sears department stores, if you have no specialty shops in your are.
Posted on Dec 07, 2011
ray gallant
  • 66248 Answers
SOURCE: How do I clean my rose gold Skegan watch bracelet strap?
with a good jewelry cleaner
Posted on Apr 30, 2015
Pulsar solar watch repair, stopped running
They have a rechargeable battery in them,you'll have to go to jeweler or a watch repair store.the battery is not cheap!!! I had my wifes fixed a few years ago the battery cost $68.00,but she likes the watch so it was worth it.
Jan 17, 2013 | Pulsar Watches
Fossil AM-3539 The watch has 2 batterys. one operates the changing face the other the watch movement. I replaced both batteries and now the face doesn't change. How do I re-set it?
Please note that many Fossil kaleido watches, especially the sports variety actually have THREE batteries. Two run the animation and one runs the time. The time one lasts much longer, usually a few years, but is smaller and buried a little deeper so you could overlook it if not paying attention. The two kaleido batteries are very visible and usually placed side to side. Pay attention though as for some of the watches those two batteries are set in the same way ( both positive sides up) while others, especially the sports variety have one battery positive side up and the other negative side up. It is important to replace them the same way or the watch will not work
Aug 12, 2011 | Watches
I bought this watch 1.5 years back.I have started using that.It worked properly.For the last few months I didn't wear it.Now the watch is not working. So the problem is in the battery ?
Jun 27, 2011 | Armitron Now Collection Crystal Accented...
How to restart my casio module no 2271 watch
mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
Jun 23, 2010 | Casio PRG-40T-7 Pathfinder
My tag professional ticks over every 4
Your battery is running low and should be changed soon.
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
Feb 17, 2010 | Watches
My watch just stopped working, i take get care of it, never even wet...is it worth trying to fix, its only about 2 years old
Rate me, plz.
Jan 12, 2010 | Tag Heuer Aquaracer Quartz Chronograph...
I changed the battery in my fossil watch and the cell strap got slightly bent and now the watch isnt working. Is there a certain part on the strap that needs to be touching either the battery or some other...
Generally if the watch has a cell strap then yes, it should be contacting the plate of the movement. Are you sure that you put it back the way it was? You should also be careful that the negative contact remains in a position to contact the bottom of the battery.
There are a few things that can go wrong with this battery change including the contacts and strap. You may have also scratched the coil and that would stop it from running. You will also not be able to reseal this watch and you chance it not being water resistant anymore and voiding your 12 year warranty. I suggest going to a watch maker/technician and asking them to take a look at your battery installation. Then ask them to change the rear seal and pressure test the watch to the water resistant rating on the watch. This particular model is rated to be a dive watch.
Sep 19, 2009 | Fossil AM3733 Wrist Watch
New battery and still not working???
There are no mystery at all. If you leave flat battery inside watch for a long period of time, battery may explode or leak. Leakage is happening most often and when it happens it is allmost invisible to naked eye.
However, the leaking solution consists of various chemical solutions and they react with metal, alloy, brass, led and other metal parts of which watch movement is made. This process is called ''oxidation'' and it works like rust on metal. You can see it wth a help of magnifier and it looks like tiny fungus layer all over various metal parts.This layer do not transmit electricity as well.
Sometimes it's possible to repair watch (depending on how much damage has been done), but in my experience few times I came across the situation that new movement replacement was needed.
All watch manufacturers are advising not to leave watches with flat battery in and if not changed for the new one ASAP, get the flat battery out of watch.
All you can do is to find your watch repair shop and ask what's possible to do. Speak to the watchmaker, not the jeweller.
Best of luck with your watch.
P.S. Please note that I am just explaining what the problem is and your rating or feedback should not be based on your negative emotions.
Aug 14, 2009 | Seiko Pulsar Bracelet Watch
Aug 14, 2009 | Watches
Moisture
After 5 years all of the case parts must be replaced i.e.,gaskets and crown then the watch must be pressure tested. anyone who is autherized woulod know that. contact Tag to have the matter resolved
Jun 05, 2007 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
Watches Logo
47 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
